NC Launch
rodneyptaylor
NC Launch
Post by rodneyptaylor » Thu Oct 06, 2005 4:10 pm
Thanks for that have re-sent
Rod.
peter_jenkins
NC Launch
Post by peter_jenkins » Thu Oct 06, 2005 4:28 pm
Transmission Chatter/Rattle:
Am chasing my tail on this problem with my '91. Happens when the transmission is unloaded such as when you change to lower gear and
back off in most gears but 5th. Disappears when you load it up again (accelerate) and can be 'played' on the throttle. Can be heard
inside and outside car and progressively getting noisier. We have checked diff, drive shaft and gear box. Even replaced two main
gearbox bearings but zero change.
Did a clutch some time back and there has been some dialogue in the USA Miata Net forum about replacement clutches causing something
similar.
Can anyone offer advice or do they have similar?
E-mail peter_jenkins@sptyres.co.nz
DDI 64 4 527-6168
Mob 64 21 636-528
KSCRIM
NC Launch
Post by KSCRIM » Thu Oct 06, 2005 5:07 pm
The damper springs in the clutch plate can cause this noise, broken
spring(s) particularly.
Selector forks can also do it, but if you load the selector by applying some
pressure on the gearlever you can determine if that is the source of the
noise.
Light pressure on the clutch pedal will eliminate the release bearing and
fork.
Thoughts for today, (see you sunday?),
Kevin 98NB6C
From supasparky@yahoo.co.uk Fri Apr 27 17:29:38 2007
b=UAYzRyQah9ZVUo5fPfQoSD+RfvQ/DbB/nfh1ocNfdwATnZei9jCGgR9fqsaLf35cSUNWNHIrGtYxCmcjdh8ozTQP4Ufhcj91iCketMeX3BwtE3RgpGnkINJ8hhd55oYZItzhQqJ+SC5oF2ndO/d6KX0hl3sJFsF9oNfZLNR6uHw=
Date: Thu, 6 Oct 2005 05:15:23 +0100 (BST)
Subject: RE:RE:RE:RE:RE:RE:RE:RE: RE: NC Launch( and driveline noise)
In-Reply-To: <OF513EC7C0.4BDFB312-ONCC257092.001284F7-CC257092.00130F56@goodyear.com>
MIME-Version: 1.0
Precedence: list
Message-ID: <0VJdpD.A.J9D.ExYMGB@L733>
The noise is a harmonic in the driveline between the
diff and gearbox... Its not the clutch or heatshields!
Best bet if youve tried the gearbox is to replace or
reset the backlash on the diff.
The 1600diffs seem to be more prone to it because of
the size.
The usa guys get it when they put in lightweight
flywheels as the harmonic is created within the entire
driveline system.
Glenn "SLYDIT"
MX5PWR
NC Launch
Post by MX5PWR » Thu Oct 06, 2005 6:45 pm
Hi everyone, I have been keeping in regular touch with Mazda NZ as ed of
Topdown.
Last email I got today indicated 200 has been passed and looks like 250 on
day expected. TV and other media will be there. Helicopter has been hired as
that is the only way go get a photo of all 250 cars.
Nigel
Carey Hill
NC Launch
Post by Carey Hill » Thu Oct 06, 2005 8:13 pm
Peter, I have the same thing on my 91, I havent investigated it yet, my
best guess is that it is a worn thrust washer in the gear box, on the main
or layshaft, where the shafts are up close to the gearbox case chattering,
mine has no noise in 5th under any circumstances. Dosnt always happen, but
may be getting more frequent.
Only other thing it could be is a loose baffle in the muffler, causing a
semi metallic rattle or chatter when the back pressure and vibration is
just right... or vibration through the entire exhaust system, caused by
thinning of the material, problem with the old catilytic converter ( if it
has one), the flexible woven section or a failing bracket or stay.
I was going to check the exhaust first due to a small amount of scottish
blood in my geneology , add a bracket maybe, road test... After that...
I seem to recall a thrust washer problem in my past, they often dont get
replaced, even with a major gearbox repair, sometimes have a case hardened
surface that gets worn away.. some are brass or brass coated, havent looked
inside an mx5 box.. failing that I was going to turn the stereo up and box
on. It is definitely not the clutch spigot bearing, they go from nothing to
a loud squeel in no time.
If you knew someone with a spare gearbox, you could chuck it in and see if
it makes a difference, ok silly idea...
studefan
Nina
NC Launch
Post by Nina » Thu Oct 06, 2005 9:53 pm
Good one! I'm soo ready for it!!!
My question is what happens if someone pulls out at the last minute?
Like I'll be forced to do if it's hosing down :-(
... world record or not... I'm not gunna risk myself or my beloved car... my
top's leaking so I can picture nicer scenarios than driving to AKD from TGA
and back geting soaked and having fogged up windows... (aircon or not)
rodneyptaylor
NC Launch
Post by rodneyptaylor » Thu Oct 06, 2005 10:51 pm
Thanks everyone re-sent and now acknowledged.
While I think about it does anyone have an adzest radio/dvd etc in their car
and or does anyone know anything about them. I know the TV Sat Nav and DVD
won't work here but the radio and CD are fine and it looks great,BUT I wish
I could re-set the clock which still thinks it's in Japan.(incredibly
accurate though) If so maybe we could meet up when I come up.Have we any
Japanese speaking members?
Rod Taylor
New Plymouth
Mike Jolley
NC Launch
Post by Mike Jolley » Thu Oct 06, 2005 11:13 pm
have got 1 more to register,must be getting close now
MIKE
WEZTY
NC Launch
Post by zorruno » Thu Oct 06, 2005 11:43 pm
on 6/10/2005 3:02 p.m. Robyn and Rich wrote:
But what I want to know is how do you guys know how many are
registered??
I've been liaising with Eileen & people from Mazda about coordination
between the NZ Club and Mazda NZ for a number of items for Sun. As is
Keith Detman, Nigel and some other committee members.
I've been working to promote the event to clubmembers and on community
sites (e.g. http://morefmauckland.co.nz/Default.aspx?tabid=331)
She is keeping us updated with numbers, and generally tells people what
number they are when they register. I think she (and Mazda) are pretty
amazed at how many people we've managed to reach.
You could probably just phone or email here if you want to know the
numbers now - but she is pretty flat out organising, so try not to bug
her too much!
H
RD5T3R
NC Launch
Post by RD5T3R » Fri Oct 07, 2005 12:02 am
I think that one is a press and hold the clock button till it flashes then up
and down the hours with the channel keys then press it (clock) again to do the
same for the minutes.
Picture would help confirm model of course!
Stu & Viv
Newbies in an NA BRG RD5T3R hoping the water pump will be replaced in
time...
rodneyptaylor
NC Launch
Post by rodneyptaylor » Fri Oct 07, 2005 12:11 am
Hi zorruno,
I can imagine Mazda are and Eileen are amazed at the response. What a
publicity stunt at very little cost to Mazda relatively speaking, the
publicity is going to be priceless. It almost smacks of Genius.Trust Mazda
are going to splash out and give us all comemorative t- shirts, caps or
something !
Rodney
rodneyptaylor
NC Launch
Post by rodneyptaylor » Fri Oct 07, 2005 12:23 am
Thanks for that Stuart, BUT it doesn't have a clock button...I'll take a
snap and send it to you to-morrow. I had got fixed in a routine to add 3 hors
now after the clocks going back I have to change routine!
Rod
peter_jenkins
NC Launch
Post by peter_jenkins » Fri Oct 07, 2005 8:58 am
Thanks. Am Wellington based so won't be attending Sunday. Also it's Bathurst...
Pete Jenkins
Mob 64 21 636-528
"Kevin Scrimgeour"
<k_scrimgeour@hotmail.com>
Sent by: e-admin@mx5club.org.nz To
cc
06/10/2005 17:07
Subject
RE: RE: NC Launch
Please respond to
MX5List<mx5list@mx5club.org.nz>
noise.
fork.
Kevin 98NB6C
Mike Jolley
NC Launch
Post by Mike Jolley » Fri Oct 07, 2005 9:28 am
Had similar noise on nissan turned out to be small crack in heat shield
around muffler giving harmonic sound. mike
MIKE
WEZTY
Mike Jolley
NC Launch
Post by Mike Jolley » Fri Oct 07, 2005 10:18 am
tufin up and see you there.
MIKE
WEZTY
NC Launch
Post by zorruno » Fri Oct 07, 2005 3:23 pm
Bathurst doesn't start until 1pm. They'll probably have a big screen in
the bar with it on anyway.
bert wouda
NC Launch
Post by bert wouda » Fri Oct 07, 2005 3:46 pm
I am also ' greater Wgton ' Based ... and it is not next door
(Auckland ) , so we have to wait till the " ND " will arrive with a "
Diesel Motor or Hybrid " in Wgton ... and have another World record
have fun in Auckland , ...we migth see you at the Telly .
B.W
peter_jenkins
NC Launch
Post by peter_jenkins » Fri Oct 07, 2005 4:22 pm
I was going to tell him that Bert but these Jaffa's think the country finishes at the Bombay Hills...
Besides, all true enthusiasts watch the Shootouts too.
Pete Jenkins
bert wouda <wouda@paradise.net.nz>
To
07/10/2005 15:46 cc
Subject
Please respond to Re: NC Launch
B.W
bert wouda
NC Launch
Post by bert wouda » Fri Oct 07, 2005 4:32 pm
I reckon Pete , ... it just " START south at the Bombay hills "
Absolutely - Positively ... MX 5 ers ... you know !!!
BW
Grant
NC Launch
Post by Grant » Fri Oct 07, 2005 4:41 pm
I'm Blenheim based and I'm attending.
Grant (and Caryl)
NC Launch
Post by poison » Fri Oct 07, 2005 5:13 pm
It's actually JAFA (with one F), mind you, I guess for
Hillbilly's such as yourself from the deep south, that being
born with 6 toes would have complicated your high school
maths... :-)
"PO1SON"
From supasparky@yahoo.co.uk Fri Apr 27 17:29:21 2007
b=SIKujo0UquSo6aC8uTDudzN5LddGR+RCmEq5jXR6QJaCDG2kK1QdFFMbX9hffBE/gDoXpSrHrBie8NW7jnwASwnFTi7AOeZzG97XGxzmAtcA/ImExXTwIcH20G8owWiV8kg9xFoSFrg3QPWVaNLGQ0BVbE8Yrihfb+GegGh7w4M=
Date: Fri, 7 Oct 2005 07:33:36 +0100 (BST)
Subject: Re: chromed wheels
In-Reply-To: <000c01c5cad7$c5c245f0$0301010a@home>
MIME-Version: 1.0
Precedence: list
Message-ID: <FIjO_D.A.o9D.ExYMGB@L733>
I had some wheels(Motoform Euros) polished on my honda
and was about $300..(plus removing/refitting tyres.)
looked great though and the only maintenance required
was a quick go over with autosol when polishing the
car every 6 months.
Dont get them powdercoated or clear painted as the
finish will be dulled and long term it can peel off
and look rubbish. Just look in the yellow pages under
metal polishers or ask someone like Mag and turbo who
does thier work.
Glenn "SLYDIT"
From supasparky@yahoo.co.uk Fri Apr 27 17:29:20 2007
b=5OR0+IbWx2jlkZu6DikEjkWlXV4kp9TSW9kr6JfpSmylxHmN/K0Bbv8ov6SBy5BybCMUqIOsAn0fM3PmuMKowGXOlIZLefVYwKM6cU/zp5CYbIloaPH3QPghVdOUIlHw45cW/i1OWfJZ0P/iPhRrYeoz+WwVwshGuLsM6bCnAj0=
Date: Fri, 7 Oct 2005 07:38:12 +0100 (BST)
Subject: Ok no more NC talk... FORD OR HOLDEN??
In-Reply-To: <4345f5e9.164.61e7.1684224246@ihug.co.nz>
MIME-Version: 1.0
Precedence: list
Message-ID: <UiMd5C.A.p9D.ExYMGB@L733>
So whos it gonna be on sunday???
who do you support??
Name youre 1st 2nd 3rd
mine is...
1: Lowndes
2:Ambrose
3:murphy
GO THE FORD! (FIRST ON RACE DAY)
BOOO THE HOLDEN..( Hang On love Da Engines Nackered)
Glenn "SLYDIT"
Return to “2005”
