hardtop
andrewl
hardtop
Post by andrewl » Tue May 24, 2005 4:27 pm
Help!
Does anyone know how to fit the striker plates to the inside of the car for
the hardtop clamps. Not the ones at the top of the windscreen.
Are they the same as the ones on the windscreen?
A
From jifjif@gmail.com Fri Apr 27 17:03:22 2007
h=received:message-id:date:from:reply-to:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references;
b=WuM6qSknTaMi88N/bKpRlZin/Rgtnm+P5SdxG5cWiKK5oMPBCiueNVw2OnbHwILNFbE46DnDpLwi3V3ffX74M3aP5EcObgAKUsFwU9V4KZEHIRF4hb7tMKHAXPnTH6pesoLuBb9V0QugrU5tDtVJZa7Pu4j1p+CoUNYfxCOS3tY=
Date: Tue, 24 May 2005 16:51:24 +1200
Subject: Re: hardtop
In-Reply-To: <20050524042745.25990.qmail@drone2.qsi.net.nz>
Mime-Version: 1.0
References: <20050524042745.25990.qmail@drone2.qsi.net.nz>
Precedence: list
Message-ID: <4ZrsUD.A.96.UdYMGB@L733>
they're attached with star-headed bolts. I'll be reattaching mine
tonight... with a screwdriver :-P
What problem are you having?
On 5/24/05, andrewl@quicksilver.net.nz <andrewl@quicksilver.net.nz> wrote:
andrewl
hardtop
Post by andrewl » Tue May 24, 2005 5:12 pm
The plastic trim on the inside probably covers the place where the striker
plate goes. I want to be sure I've got the right bits before I start
dismantling the interior of the car. It looks like a long and complicated
job and might involve a hacksaw. You know: the toe bone is connected to the
foot bone is connected to the ankle ...
It looks like there is a whole series of bits to be removed before I get to
the right place.
A
~Jeff~ writes:
Ian Chapman
hardtop
Post by Ian Chapman » Tue May 24, 2005 5:18 pm
Andrew
If a hardtop hasn't been fitted to your car before, you will need to
cut out some of the black plastic trim panel just behind the door (I
think the panel is tan on BRG's and other 'coloured' interiors). From
memory, when you remove that panel you will see a molded area on the
back side that shows where to remove. Then you need some bolts - the
originals are dome headed torx (star) but any of correct thread would
suffice.
If you are in Wellington and want to swap panels for ours with the bit
factory removed (we sold our hard top) let me know and we can arrange a
meeting. Or if you want to get a pattern of area to remove.
Ian Chapman
hardtop
Post by zorruno » Tue May 24, 2005 5:53 pm
for the hardtop clamps.
As Ian said, there are markings on the inside of the trim that indicate
what to cut out. Take off the trim, cut the marked rectangle out, fit
the plates to the pre-threaded holes. 20 minute job max.
If you want to swap with someone who has the plates (or the already
cut-out trim), but doesn't want them any more like Ian also mentioned,
this is always a better option as it helps out two people :)
No, they are not the same. Mazda stock them though if you don't have
them already. They also stock the correct bolts. I know Jaycar has the
correct head bit for the stock bolts, other places probably do too.
You can use a hardtop for a while without the side striker plates - I
did for over a year with no problems (ok, the hardtop was not actually
on for 1 year...!). The rubber seals squeaked a bit as they moved
around sometimes though... and I'm sure the side clamps make it safer.
hardtop
Post by poison » Tue May 24, 2005 6:27 pm
Or 40 mins if you car's BRG as you'll have to stop to throw up once in a
while working so close :-)
Spreading Joy and Understanding and Tolerance in the world, unless you have
a BRG car... and you can't blame me for that, you picked the colour...
carl.halvorsen
hardtop
Post by carl.halvorsen » Tue May 24, 2005 7:26 pm
Give it a break Gazza it's wearing a bit thin!
Carl
Ross Wilson
hardtop
Post by Ross Wilson » Tue May 24, 2005 8:28 pm
There's a bit here on adding the hardtop.
I've done it - it's not hard, but be careful
cutting the oval hole, the material WILL
split if you cut too fast.
http://www.mx-5.com/MeMyMX-5/TipsTricks ... s/hard_top
Ross
Phil
hardtop
Post by Phil » Tue May 24, 2005 9:23 pm
What the hell is wrong with having a BRG MX5?
Phil
Graeme H
hardtop
Post by Graeme H » Wed May 25, 2005 10:59 am
Nothing wrong at all. Don't worry about Gazza, he's in denial. He really loves BRG, but could only get her plainer looking sister :0D
Graeme H
Return to “2005”
