Gidday,
I ended up getting rescued by the AA last night after my battery had
insufficient charge to start the car. They now don't only start your car
- they also offer to sell you a new battery.
The good bit was that they had batteries which are perfect for the MX5.
They're completely sealed, fit in the battery holder and work with the
standard bracket. And it was 'only' $114 including delivery and fitting.
Not exactly cheap, but less than the $200+ for the factory battery and
it doesn't require the gas venting kit either.
This was in Wellington, I assume other areas have the same sort of
arrangement.
Thomas
thomas@thomasbeagle.net
Source for MX5-friendly Batteries
Gidday,
arrangement.
Thomas
arrangement.
Thomas
on 15/04/2005 8:14 a.m. Thomas Beagle wrote:
Do you know if they are standard 'no-maintenance' Lead Acid or Absorbed
Glass Mat type?
H
PS. what was the 'delivery' component... wasn't the AA already there?!
Hi ThomasI ended up getting rescued by the AA last night after my battery had
Glass Mat type?
H
Glass Mat type?
H
Glass Mat type?
H
zorruno wrote:
they came around to my house to install it.
Thomas.
I assume it is lead-acid.Do you know if they are standard 'no-maintenance' Lead Acid or Absorbed
Glass Mat type?
They don't carry around a stock of batteries, called someone else andPS. what was the 'delivery' component... wasn't the AA already there?!
Thomas.
Thomas.
Glass Mat type?
Thomas.
Hi,
I just got a replacement 'Gel Type' battery from John Andrew Ford in
Auckland and cost was $160.00 (incl. GST) using MX5 Club discount.
They have come down in price.
It is the Panasonic branded one.
Regards,
Anthony.
Regards,
Anthony.
