Braces.
malcster
Braces.
Post by malcster » Fri Feb 01, 2013 9:03 am
Whats the best set up regarding braces to get rid of the wriggle i get when the turbo kicks in?
cheers.
1998 NB MX5 RS TURBO.
Post by Angreal » Fri Feb 01, 2013 10:20 am
What sort of wiggle? I have practically every brace available on my car ;) I don't have the supercharger up and running yet as I'm lazy so I don't have the wiggle sensation you mentioned
malcster
Post by malcster » Fri Feb 01, 2013 10:34 am
feels like a back end wiggle..diff maybe I guess?..when turbo kicks in.
Post by Furai » Fri Feb 01, 2013 10:48 am
What diff are you running? Also had an alignment? What sort of suspension setup and what year car(Year determines stock bracing).
Post by Angreal » Fri Feb 01, 2013 10:51 am
Possibly suspension related? The braces just made everything feel tighter although the shock tower braces didn't seem to do too much but I can feel when they aren't on.
Not sure what the frog arms feel like yet as I haven't driven with them but I'm going to stab in the dark and say it's probably your suspension not coping.
Have a play around with your rear end damping since you have adjustables?
Post by chris » Fri Feb 01, 2013 11:42 am
I'd say Allignment issue.
Otherwise lower tie bar :)
Post by Angreal » Fri Feb 01, 2013 11:46 am
And you should have all the factory braces in the car as your car is newer than mine and I have all the factory ones + more. THey put in a butterfly equivalent thing waaay later in the late NBs I believe.
Post by Kieran » Fri Feb 01, 2013 12:29 pm
I would check the alignment first as its the cheaper option otherwise some good suspension and a proper roll bar will fix this
Post by Mr. Shine » Fri Feb 01, 2013 3:37 pm
Angreal wrote:the shock tower braces didn't seem to do too much but I can feel when they aren't on.
This is correct; there should be minimal added effect in terms of rigidity or anti-flex for a shock tower brace on a non-McPherson strut car.
malcster
Post by malcster » Fri Feb 01, 2013 3:48 pm
cheers guys..have tein adjustables with the incar dampning controller.
its a 98 first yr NB with torsen diff.
does have some factory bracing in the rear and up front. and a monster roll bar
i guess you feel it a little more when you hit boost and then come off it again.
it does launch prity hard as seems to get the power down really well.
funny you mention the suspension as RH REAR to get ride height needs to be totally uncaptive spring but LH side spring is wound up and captive some.
and opposite to the front as LH uncaptive and RH is captive...had to lower it heaps with the 15s on it and with 17s i had before the springs were never un captive but were wound out differently like now.
seems to handle good and wonder if springs have gone soft and need checking?
Have had an alignment only a couple hundred ks ago..but needs another as now got the 15s on it.
do have the dampning quite soft on rear..still firm tho as teins so might firm it up and see if it makes any difference.
Post by siren676 » Fri Feb 01, 2013 4:08 pm
Do you have a hardtop on? With my soft top up or down I noticed a slight ahimmy around 100k's.
Post by Angreal » Fri Feb 01, 2013 4:16 pm
siren676 wrote:Do you have a hardtop on? With my soft top up or down I noticed a slight ahimmy around 100k's.
The shimmy reduces the more you stiffen up the chassis although mine still has a slight shimmy above 120 but much less than when i first bought the car. The butterfly brace and rollbar reduced it along with the hardtop
Post by chris » Fri Feb 01, 2013 4:23 pm
I hope you only go above 120 on the track.
malcster
Post by malcster » Fri Feb 01, 2013 4:34 pm
no hardtop but got my eye on one... :D
its only when boost comes on or off and fine at 100 or 120 under normal acceleration..just when its on 12 with my foot down 8)
Post by Angreal » Fri Feb 01, 2013 4:50 pm
chris wrote:I hope you only go above 120 on the track.
Nope, only on the skidpad :wink: Sadly the car doesn't go very fast atm :p In fact, can't even turn over the engine which should hopefully be resolved tomorrow
Post by Angreal » Fri Feb 01, 2013 4:51 pm
malcster wrote:no hardtop but got my eye on one... :D
So it's the car struggling to get the power down because you're losing traction?
Post by chris » Fri Feb 01, 2013 4:54 pm
Clean up your act guys. 120 kph? Loss of traction. This is unacceptable.
Post by Angreal » Fri Feb 01, 2013 4:57 pm
chris wrote:Clean up your act guys. 120 kph? Loss of traction. This is unacceptable.
I know... At the very least you need to be on 3 wheels when doing the above :lol:
Anyway, back on topic of braces... I can't believe how much rubbish is collected on the panel in front of the doors. Pulled it off to pop in the Frog Arms (still gutted they aren't lime green anymore :() and sooo much filth fell onto the garage floor.
Post by siren676 » Fri Feb 01, 2013 5:09 pm
Chris is just jealous that his car needs a tail wind to get to 120 :P
Post by Furai » Fri Feb 01, 2013 6:08 pm
chris wrote:I'd say Allignment issue.
Nah PPF brace. Improves it in many more ways.
malcster
Post by malcster » Fri Feb 01, 2013 6:15 pm
no loss of traction that i know of :D in a straight line anyway...just the wriggle 8)
Post by Angreal » Sat Feb 02, 2013 1:23 am
It didn't seem that great but probably because the car came with all the stock braces. Just made gear changes ultra smooth
Post by Snapfrozen » Sat Feb 02, 2013 7:32 am
Can't believe no one said this earlier!
Post by Snapfrozen » Sat Feb 02, 2013 7:33 am
malcster
Post by malcster » Sat Feb 02, 2013 9:46 am
o.k..so PPF brace is the way forward...the rails or the triangle type?..any links?
