miata boss kit
miata boss kit
hi. i have a NA miata and i want to change my steering wheel to a smaller aftermarket one so i won't be driving it with my knees. but my factory wheel have a airbag.
can i still use normal aftermarket mx5 boss kit on my car or do i have to source a different type of boss kit since i have airbag on my factory steering wheel.
and if any one has one please let me know.
Re: miata boss kit
I can't direct you in terms of what boss kit you'll require, but you will require LVV certification for the removal of your airbag steering wheel.
thanks for the reply guys. english is not my first language so excuse my konglish.
i will get s cert after i finished everything that i want to do on my car. and i will try not to drive it until then.
and punkoutnz can you pm me? im interested as long as it fits.
also if anyone here have a hardtop fitting kit please pm me.
One of the grounds upon which you are able to remove airbag (i.e. if the car is not at least 14 years of age) is if the vehicle has been extensively modified for motorsport use. Your reasoning seems relevant to that, although on that basis you may require authority cards and the like...Kieran wrote:could you argue that with a rollbar in a crash a airbag is likely to push the drivers head into the bar and on the street you will not be wearing a helmet?
But any NA and early NBs are able to have airbag removed anyway on the basis that they're at least 14 years old.
Heres what it will be like if you do crash, you might not have the Drift king laughing at you after though...
http://youtu.be/XkzBm-AXBgc
Lolololol look at all these guys jumping on the 'YOU NEED A CERT' buzz. I don't think he asked whther he needed cert, he's asking which sorta boss kit he needs to buy to change his steering wheel.
Hahaha classic.
Welcome to the mx5forum, glanzav.
Hahaha classic.
God I love Tsuchiya, Best Motoring is the best show everrrr!Furai wrote:Heres what it will be like if you do crash, you might not have the Drift king laughing at you after though...
/hijack
a standard wheel boss will fit. also you need to take out the airbag light. also note that the boss kit for the standard momo/sportline wheels has a different wheel bolt pattern to the Nardi wheels.
removing an airbag from an airbagged NA doesnt make it unsafe...it just makes it as safe as nearly every other NA mx5
