soulfader
by soulfader » Sun Sep 06, 2009 11:57 am
to start with its on na6
the problem i'm having at the moment is when i open and/or close driver side window, it makes a squeaky sound as well as leaving some minor scratches. and it's external side window, not interior side... making it even worse for me to part out to have a look...
can you guide me where to start from?
viscarious
by viscarious » Sun Sep 06, 2009 12:04 pm
Where abouts are the scratches? by the window rubbers or on that bottom 'furry' strip??
soulfader
by soulfader » Sun Sep 06, 2009 12:57 pm
viscarious wrote:Where abouts are the scratches? by the window rubbers or on that bottom 'furry' strip??
a photo attached and i have circled the area in yellow
i thought there were more scratches along the bottom strip but seems like only where i have circled.. i could be mistaken or seeing things..
viscarious
by viscarious » Sun Sep 06, 2009 1:43 pm
Asked around and 2 options seem to be a) some dirt has gotten betweem the window and felt, or b) that felt material could be worn through and the backing plate is scratching the window.
Is this a recent thing or gradual?
soulfader
by soulfader » Sun Sep 06, 2009 2:52 pm
viscarious wrote:Asked around and 2 options seem to be a) some dirt has gotten betweem the window and felt, or b) that felt material could be worn through and the backing plate is scratching the window.
yeah it just started to happen 2 days ago
i've pulled out the interior door trim to figure it out but not much i could see from that angle as the scratches were from the outside rather inside
what would be your suggestion? should i try to pull out the whole window first and go from there?
viscarious
by viscarious » Sun Sep 06, 2009 3:59 pm
can you hear it scratching as you wind it?
If you can't see obviously from any direction then you might have to pull out the glass. Could be as little as some abrasive dirt stuck in the felt. Maybe blow out with airgun and see if that fixes it?
soulfader
by soulfader » Sun Sep 06, 2009 8:16 pm
viscarious wrote:can you hear it scratching as you wind it?
yup, i can hear it scratching as i wind it down and up. starts about 1/3 down and vice versa
i dont have access to any airguns
ham
by ham » Sun Sep 06, 2009 8:20 pm
This happened on my wifes NA. The problem was the rubber weather strip on the out side had hardened and eaventually tore off. New rubber weather strips cured the problem completely. Cheers
1989 NA Blue JRSC.
soulfader
by soulfader » Sun Sep 06, 2009 8:26 pm
ham wrote:This happened on my wifes NA. The problem was the rubber weather strip on the out side had hardened and eaventually tore off. New rubber weather strips cured the problem completely. Cheers
what is a weather strip? is it that bottom black strip thingy?
have you got part number for it?
by zorruno » Sun Sep 06, 2009 9:14 pm
could be the the bolts holding the mounting for the window frame internal to the door have come loose too - meaning the the window geometry is not correct
viscarious
by viscarious » Mon Sep 07, 2009 12:00 am
soulfader wrote:ham wrote:This happened on my wifes NA. The problem was the rubber weather strip on the out side had hardened and eaventually tore off. New rubber weather strips cured the problem completely. Cheers
I would say the weather strip is that bottom black strip thingy.
ham
by ham » Mon Sep 07, 2009 10:15 am
Yeah. The strip between top of door panel and the glass.
Part # MNAO158810F right hand side
Part # MNAO159810F left hand side
1989 NA Blue JRSC.
Users browsing this forum: Google [Bot] and 11 guests
