My original key split down the middle yesterday, and whilst bunnings managed to cut a copy to get me home i noticed the other spare keys i have don't open the boot, glove box lock or the cubby box lock behind the handbrake.
Does anyone know where to get a good replacement key that will work all locks??
Keys
you could try removing the drivers side door lock..it has the key code on it....
just take it to your locksmith and they will cut a brand new key...
the lock is easy to remove.
just remove the door trim and then use a 10mm socket to remove the two nuts holding the handle on, then un clip the door rod and your done..
