Been busy modding
thebears
Been busy modding
Post by thebears » Thu Nov 24, 2011 8:54 am
Bit of an intro, recently, well two weeks ago I brought a Eunos 1.8 v-special I think, it's Laguna blue and has some fancy yellow shocks, engine brace and a black hard tops well. Bodywork needs some tlc but not bad for a car of its age.
So far, the door spring broke, luckily I already had the door card off as was messing with the stereo. :D I have replaced the MSSS system with a Sony XPlod head unit with full iPod control. Installed a cubby hole below the double din with a perfect fit and have some extra storage up front. Took the door speakers out, all the cone rubbers where perished and replaced with a component 6" fusion speakers. Had to mod the tweeters (basically cut them apart and glued the to the inside of the original Mazda covers to keep a stock look. Put new springs on door locks at same time. Thanks to the forum for guides on eyeballs, dash removal, door card removal and the springs.
Next set on the headrests, hacked out the old ones, cut some of the metal support away to get a perfect fit on two 4" sony xplod speakers. At the same time re-drilled the plastic cover to allow more sound out. Re-fitted everything including finding a blown bulb for the ashtray.
Got a beer and the iPod, sat in the car and cranked it up. All sounds pretty good for a $300 spend from supercheap in the sale. Prob about $500 at normal retail.
Next on the job list K&N 57i pod filter with cold air feed, got the kit from uk, very good price compared to what repco sell. After that front and rear brake pads, just need to make my mind up on what to fit.
The list goes on, hard top re-paint, replace rear window of soft top..........
Thanks for the forum as I don't think I would tackle this stuff without the advice.
thebears
BBS Wheels
Post by thebears » Tue Nov 29, 2011 2:16 pm
found out from reading the USA forum that the wheels on my motor are the BBS 14" rims that are lightweight. There are in good nic with centre caps and removal spanner. I read the centre caps alone are worth a fair bit.
Nice wheels, may have to get them refurbed. :D
m4vr1k
Post by m4vr1k » Wed Nov 30, 2011 5:00 pm
We want pics!
A good stereo is essential to the enjoyment of any car IMO, sounds like you have a damn good setup.
Roses are red
Violets are red
Trees are red
Oh fuck, my garden's on fire
thebears
Photos, plates and oil shock!
Post by thebears » Wed Nov 30, 2011 9:12 pm
m4vr1k wrote:We want pics!
Having the new rear panel of the roof fitted tomorrow, fitted new number plates today as the front looks like it was trashed with a few tow bar reversing/parking incidents. Does any one know of a better front mount for the number plate as NZ plates don't fit the original to well. :cry:
Had a shocker today, the oil pressure gauge dropped to zero whilst doing a few K's over the limit, pulled up, checked oil all good, water temp all good. Limped home and had another another look with the belly pan off, no major leaks and still a full dipstick. Read that the oil sender unit could be buggered, hard to locate, but pulled the lead off and gave her a clean, restarted and running on idle (warm) just less than 1 kg.cm2 and at 100k about 2.1 is this norm.
Once i get the rear window done, and get the last of my swissol wax onto the body work i'll be taking some pics?
Anyone up for an evening cruse from Auckland? Blat out, head to a pub and talk the crap out of MX5's :lol:
Post by Mr. Shine » Wed Nov 30, 2011 9:59 pm
My oil pressure gauge plays up sometimes. It's pretty much constantly reading a bit low now, but if I give the oil pressure sensor connector a bit of a clean it sorts it out... for a while :P
Post by Angreal » Wed Nov 30, 2011 11:45 pm
I am keen if I buy myself a new socket to get my front shocks swapped. Also need to make a trip down to Hamilton first.
There's this plate holder I've been looking at but could never justify bringing across which hides the plate... Not sure it's legal and i'll have to track down the link
ham
Post by ham » Thu Dec 01, 2011 8:00 am
Ross at MX5Mart has a rego plate holder made to suit NZ plates. We use them on our NA's. Keeps everything neat.
1989 NA Blue JRSC.
Post by Euen » Thu Dec 01, 2011 10:46 am
Are you sure you have a proper oil pressure sender or do you just have the switch. The early NAs had a proper guage and sender however, at some stage, in thier wisdom, Mazda changed the sender to a switch so the guage was just reading an on/off signal. This could explain what you saw on the guage if the connection was dirty.
thebears
Post by thebears » Thu Dec 01, 2011 11:26 am
Euen wrote:Are you sure you have a proper oil pressure sender or do you just have the switch. The early NAs had a proper guage and sender however, at some stage, in thier wisdom, Mazda changed the sender to a switch so the guage was just reading an on/off signal. This could explain what you saw on the guage if the connection was dirty.
I think it's the last of the proper gauges as its marked in kg.cm2 and goes up in increments of 2. Working fine today, flicks around a bit but seams ok. I thought the idiot gauge didn't have measurement marks numbered?
Post by Euen » Thu Dec 01, 2011 12:07 pm
2kg/sqcm is about 28psi which should be OK.
Edit: have just been out in my 91 1.6 and the guage sits at 2 kg/sqcm at idle (hot) and rises through 3 at 1500 to about 4 at 2500. Rises to about 4.5 at about 3000 and above. Not bad for a 230K engine that is due for an oil change.
Ben.Nakagawa
Post by Ben.Nakagawa » Thu Dec 01, 2011 4:38 pm
Mazda changed oil guage sender in 93 or 94. A 1.8 model has no proper guage unless someone replaced the sender.
An older model does constant change over the rev through 2-6 depends on the oil temp and condition of oil.
Ben
m4vr1k
Re: Photos, plates and oil shock!
Post by m4vr1k » Thu Dec 01, 2011 5:17 pm
thebears wrote:Anyone up for an evening cruse from Auckland? Blat out, head to a pub and talk the crap out of MX5's :lol:
Always keen on a blat in the Mazdarati. Especially if it ends at a pub!
Have a funny story regards oil pressure gauges. Friend had a C35 Laurel with an RB30DET in it. Turbo the size of your face, was laggy as buggery, but as soon as it came on boost, the world ended, anyways.....
He turns up at my house one day, complaining that his oil pressure gauge had shat itself, however, the engine was making some fairly awful noises, so I advised him that his oil pressure gauge was just fine, and to draw a conclusion from that. Friend refuses to beleive me, goes fanging down the road. Five minutes later I get a phone call, which I shall document here verbatim
Me: Hello
Friend: My car just stopped going
Me: HA HA, fucktard -click-
TL;DR friend had a fast car. No oil pressure, bang
Roses are red
Violets are red
Trees are red
thebears
Post by thebears » Fri Dec 02, 2011 7:22 am
Ben.Nakagawa wrote:Mazda changed oil guage sender in 93 or 94. A 1.8 model has no proper guage unless someone replaced the sender.
some 1.8s do have a proper gauge, mine is one of them as it does change across the rev range, cold start will be about 4.5 dropping to less than 2 at idle whan fully warm. On hard revs it's prob back up to 4.5 again and at 100k around 2.2.
I am due an oil change so will get that done to see if there is a difference.
Post by Angreal » Fri Dec 02, 2011 10:09 am
My 1.8 also has the proper guage.
Ben.Nakagawa
Post by Ben.Nakagawa » Fri Dec 02, 2011 2:08 pm
Ah yes, It must be sometime in '94 then. I might red them wrong in some other source.
Ben
Post by Angreal » Sun Dec 04, 2011 3:07 pm
http://www.miatamania.com/Shop/ViewProd ... exID=77917
Here's the number plate mount I am looking to get but I'm not sure they're entirely legal and all...
Post by Skilfil » Sun Dec 04, 2011 3:25 pm
Definitely not legal, but if just by looking at it, you can't tell its not normal, I'd say go for it. The risk of a fine is up to you, and depending on how closely Mr.Officer looks at your plate holder.
Post by Mr. Shine » Sun Dec 04, 2011 10:03 pm
I've always thought the lower/side license plate mounts to be quite attractive while still remaining legal.
