Port, polish and 3 angle valve job
Post by Kieran » Fri Feb 18, 2011 4:40 am
Is a 3 angle valve job worth it on a N/A engine
And does anyone have any suggustions of places to get a good preferably affordable port and polish job done [/code]
Post by Keith Jones » Fri Feb 18, 2011 10:39 pm
For a good port and polish I can recommend Lynn Rogers Automotive in Howick. Lynn is one the best head men in the country, doing many race engines. I know my own engine has more power (through on-track acceleration and top speed) than other similarly configured engines, which I can only attribute to differences in head work.
Post by SLYDIT » Fri Feb 18, 2011 11:29 pm
The Nb 1800 already has the best head setup of all the mx-5's so i would look elsewhere for power. extractors/megasquirt ecu and some irtb's would be the way to go before pulling down the engine.
Post by Kieran » Fri Feb 18, 2011 11:36 pm
Im going to be adding itbs, +2mm pistons, con rods, performance camshafts and a new ecu so i thought a good port and polish might be in order when i pull the head apart
