Cooling Fan not Functioning
kiwi73
Post by kiwi73 » Thu Dec 30, 2010 9:56 pm
Hey
Have a 1990 NA. Overheated on Christmas Day after drive through Waitakeres. I noticed the cooling fan wasnt going
Radiator was on the way out so purchased a new one, also new thermostat and thermoswitch.
Checked the fan connected direct to battery with multimeter drawings about 7amps.
Checked relay. Couldnt quite check continuity with multimete...r not enough hands. Ran voltage across relay and clicked an carried so its seems to be working.
I tried use jumper between Ground and TND and turned key on.. fan does not go.
I'm thinking its a connection problem somewhere. Just to note the thermoswitch wire (that goes into a femalee connector) also has another wire coming off it - looks like a female. Anyone know what this is for?
Anyone have any suggestions? Maybe an earth problem?
Thanks for your help
Post by WideOpenThrottle » Fri Dec 31, 2010 8:40 am
What about the fuse?
Post by WideOpenThrottle » Fri Dec 31, 2010 8:53 am
Also dont forget the fan only trips in after a certain temp so its not on all the time.Mine needs to get fairly warm at idle before it works.
kiwi73
Re: Cooling Fan not Functioning
Post by kiwi73 » Fri Dec 31, 2010 9:31 am
All sorted. Was earthing problem.
kiwi73 wrote:Hey
Post by sprsta » Fri Dec 31, 2010 10:06 am
so you have had it running since you cooked it then?
is you head/gasket ok?
brandonmillsap
Re:
Post by brandonmillsap » Sat Jan 22, 2011 7:49 pm
check the fuse bro
brandonmillsap
Re:
check the fuse bro
Users browsing this forum: Foplips00 and 12 guests
