Nardi Gear Knob
crewsaider
Nardi Gear Knob
Post by crewsaider » Tue Jul 13, 2010 10:42 am
The wooden Nardi Torino gear knob on my 99 V Spec is loose but there seems to be no visible method, either in the wood or bottom metal band, of tightening it onto the shaft. I suspect there may be a grub screw behind the logo plate but, before attempting (very carefully) to prise this off, I would be grateful if someone could confirm that my premise is correct.
Gravelben
Post by Gravelben » Tue Jul 13, 2010 5:25 pm
Stupid question perhaps but have you tried turning it? Every car I've had (including MX5s) the gearknob just screws onto the end of the shaft. apologies if I'm misunderstanding the question.
crewsaider
Post by crewsaider » Wed Jul 14, 2010 7:39 am
Gravelben wrote:Stupid question perhaps but have you tried turning it? Every car I've had (including MX5s) the gearknob just screws onto the end of the shaft. apologies if I'm misunderstanding the question.
Not stupid, that's what I tried initially when I wanted to remove the knob and is the reason it now turns relatively freely but not on a thread!
aidwano
Post by aidwano » Thu Jul 15, 2010 5:36 pm
You might need to glue the metal insert to the wood
crewsaider
Post by crewsaider » Mon Jul 19, 2010 7:46 am
aidwano wrote:You might need to glue the metal insert to the wood
Don't quite follow, there is no metal insert, just a metal cap on the bottom of the knob that seems immovable and the logo label about half way down the knob.
Gravelben
Post by Gravelben » Mon Jul 19, 2010 10:59 am
No metal thread inside the knob for the gear lever shaft to screw into?
crewsaider
Post by crewsaider » Tue Jul 20, 2010 8:12 am
Gravelben wrote:No metal thread inside the knob for the gear lever shaft to screw into?
Apparently not! See my comment on your previous post.
Users browsing this forum: No registered users and 97 guests
