newbie worries
zoomin
newbie worries
Post by zoomin » Mon Apr 19, 2010 9:02 pm
hi there, am needing some reassurances that my new baby is not a lemon , 06 soft top - owned 5 days only & first rain leaked like a sieve and totally wet driver footwell and boot . has been in garage getting new upgraded drains. I bough this as my commuter rainhail or shine - was this a mistake for winter or should it be able to cope with winter weather?? worried now? my understanding was mx5 has best sealing soft tops?never even crossed my mind it might leak!
Otherwise.. love it
Post by brownie » Mon Apr 19, 2010 10:25 pm
Back drains will be blocked no doubt,Won't need upgrading,just clearing,
Those are ones behind the seatbelt area ,Plenty of info around to sort them.
Check the How To's on this site ,i'm sure someone must have done them as well
Post by sprsta » Tue Apr 20, 2010 7:12 am
the garage section on miata.net will have a write up on how to clean out blocked drains if you ever need to do it for your self
the car was probably parked outside or under trees etc before you brought it and the drains have never been cleaned (4 years of road grime and dirt)
not a lemon just needs abit of lovin
zoomin
Post by zoomin » Tue Apr 20, 2010 8:55 am
thanks for that - have already discovered miata net - very useful. I've entered a world I never knew existed!!
Post by SLYDIT » Tue Apr 20, 2010 8:59 pm
The NC's had an issue with the weather sealing strips on the soft tops. im pretty sure there was even a TSB(technical service bullitin) about replacing them under warranty because they leaked... hope thats not the case with yours.
heres some useful links.
http://mx5cartalk.com/forum/viewtopic.p ... rain+water
http://www.finishlineperformance.com/pd ... -2104c.pdf
zoomin
Post by zoomin » Wed Apr 21, 2010 8:50 pm
thanks for that - I phoned the dealer as soon at it leaked and they had me take the car to the closet dealer and as far as I can tell they put in the upgraded drains free and dried out the carpets. I also had the am aerial clap out at the same time(also evidently a fault with the 06 NC) so they replaced that under warranty as well. does anyone know if they need to go behind the dash to replace the aerial? as now i have a really annoying rattle coming from the dash, which wasn't there pre-leak incident.
zoomin
Post by zoomin » Wed Apr 21, 2010 8:53 pm
thanks SLYDIT for the links - i actually found the drain service bulletin, printed it off and took that with me to the garage. They put upgraded drains in - I assume it was these. thank goodness for these forums and thanks for the helpful advice. cheers
