Replacing the water pump 1990 NA6CE 1600cc manual
Ferretti
Post by Ferretti » Sat Apr 17, 2010 9:09 pm
Hi has any one Replaced the water pump on a 1990 NA6CE 1600cc manual.
Can you tell me how to do it or direct me to a web site that lists this.
Where is the best/cheapest place to get the parts and how much would they all cost(probibly would do the cam belt etc at the same time). Thanks
Re: Replacing the water pump 1990 NA6CE 1600cc manual
Post by zorruno » Sun Apr 18, 2010 12:39 pm
Ferretti wrote:Hi has any one Replaced the water pump on a 1990 NA6CE 1600cc manual.
I've moved this to the main discussion topic... it doesn't belong in FAQs (until someone documents how to do it... ;) )
Post by Euen » Sun Apr 18, 2010 3:43 pm
Have a look here.
http://www.miata.net/garage/water_pump.html
There is also info on doing the timing belt as well.
http://www.miata.net/garage/timingbelt.html
If you are doing the pump it makes sense to do the belt as well if you don't know the history.
You can get the pump and a complete kit for doing the timing belt from BNT. The kit includes the belt, new tensioner idlers and I think it also includes new camshaft seals.
Give the hoses a good check as well while you have it apart.
broomfish
Post by broomfish » Sun Apr 18, 2010 8:36 pm
I can price up the belt kit and water pump for you on Monday if you like. I have several quality suppliers to choose from and will certainly be cheaper than BNTs retail.
regards
Peter Lee
Broomfish
www.broomfish.co.nz
