Gidday, I have an 91 NA 1.6 with 250k's on the clock. Does a great job getting me up and down the akl southern motorway every day (~120k round trip) and provided I don't drive like a maniac through the hills between our block and the motorway out at the bombay hills i go through a small amount of oil between changes.
However if I get the old girl up past 5 or 6 thou revs she blows a bit of smoke out the back which takes the enjoyment out of a good drive (and increases oil consumption), i'd like to get her fixed especially as i'm eyeing up those Hampton downs track days in the future....
Is this a heads off job, or a valve seal? Any advice appreciated. I like to do my own work on this wee car, great fun.
Cheers!
High rev smoking
valve stem seals will generally show up as smoking on startup. but then smoking while under load is more likely to be rings.
As above a simple engine swap out is the most cost effective solution as engines are pretty bullet proof nad so are cheap second hand.
