drew74
by drew74 » Wed Jan 27, 2010 4:01 pm
Hi all...
Bit of a new guy here, inherited my 91 Eunos Roadster a few months back from the sister-in-law who now lives overseas.
The car has been in storage rather neglected up until recently and I'm working through all the little bits and pieces one at a time... current task is the passenger window which doesn't work.
I was going to start at the fuses, switches and work my way through the possible causes, can anyone give me an idea of the most likely cause?? Any tips and tricks for the new guy
Thanks in advance.
Drew
last_resort14
by last_resort14 » Wed Jan 27, 2010 4:53 pm
My first guess would be the switches, mine play up often. sometimes have to press them like 20 times before they work, if you can swap the plugs on the switches over and see if the problem goes to the other side
by SLYDIT » Wed Jan 27, 2010 8:46 pm
yeah the most likely cause is the switches. they get carbon on the contacts.
Go down to dick smith or Jaycar and get a "fiberglass pen" to clean the contacts of the switch. DO NOT USE SAND PAPER!!!!!!
Using sand paper removes the protective nickel coating from the contacts and you will be forever having to clean the switches. using a fiberglass pen will remove the carbon without taking all the coating off the contacts.
oh and take the switch apart over a nice clean sheet so if you drop anything you can find the little bits again.
drew74
by drew74 » Thu Jan 28, 2010 8:36 am
Thanks guys, will give that a go this weekend!
blackbetty
by blackbetty » Wed Mar 17, 2010 9:08 pm
just a peice of info...the window reg wire is known to snap.and because of this they are normally rediculously overpriced.mine has been broken since i bought my car.never bothered to replace because drivers window works and im not the passenger.haha.but if its too hot a/c or the top comes down
"What's the driving force behind blackbetty"........Satan
:twisted::twisted:
blackbetty
by blackbetty » Wed Mar 17, 2010 9:10 pm
door trim is easily removed fyi.screw in the handle and from memory 3 in the armrest/grip.remove the handle and just pull of the trim its held on with clips
:twisted::twisted:
drew74
by drew74 » Thu Mar 18, 2010 3:45 pm
Hey thanks for that blackbetty, I have to admit, I still haven't rolled up my sleeves and had a look at this!
Now that the weathers getting cooler and the calendar not so full I'll hopefully get a free weekend to dig into this properly.
blackbetty
by blackbetty » Sun Mar 21, 2010 8:46 pm
no worries.(karma my way if im right
) should take only 2 mins to pull off trim and youll find straight away if the wire is snapped.good luck
:twisted::twisted:
