Differance in crankshafts
Can anyone tell me the differance between the B6 and the B6T cranshafts.
This is the early 1600 motor (NA6CE ).
Yes that is the only difference.....
If you are concerned about the small nose (22mm) crankshaft failing don't be. I reviewed this matter and according to Keith Tanner from Flyin Miata he has seen more failures from the big nose crank (27mm). I found a low kms crankshaft from a 1989 bfmr familia turbo here in NZ.
Agreed, short nose crank failure is blown out of all proportion. It is as likely as any other major engine failure attributable to poor maintenance practices.
In other words, if someone has taken off or played with a fairly major part of the cars engine, and not done it right, there is a chance it will break in the future. This applies to the crank pulley bolt as much as any other moving part of the engine. Granted the crank pulley bolt and key is not a terribly brilliant design on early NAs, but it works fine as long as it is dealt with correctly when re assembling it.
Hi,
Thanks to all for the infomation you have posted.
The way I understand it there are three crankshafts, Small short nose (22mm),small long nose (22mm), and the big nose (27mm).
The short nose is a light weight crankshaft for the MX5 ( I think thats how it goes from what I have read lately )
I think I have found a good long nose crankshaft which I think I will use.
The weight differance may effect the performance, if it does may have look at lightening it.
THREE???
Just 2 types of crankshaft for the B6:
long nose or short nose,
big nose or small nose,
27mm or 22mm,
The problem lies with the person tightening the pulley bolt.
For boosted 1.6s I use the B6t crankshaft (small nose).
For NA 1.6s use the b6ze (big nose or small nose, both will do).
If you want to spin a crankshaft at high RPM you will need to lighten and balance it along with the harmonic balancer, conrods, pistons, flywheel and clutch assembly.
If you are doing the job properly, there are a lot of other critical things to do aswell.
Oh yeah, The lightest crankshaft will be easier to spin, but will it break??????? Find your self a good engineer???
J Hartley
27mm or 22mm,
J Hartley
Ha ha ha....Simple, the bolt isn't cast on the end of the crank is it?
Someone had to put it there originally.
So let me get this straight..... Mazda designs a crankshaft and bolt, and trains and supplies the workers (or robots?) on the assembly line, and some of them come loose after 80 or 100 or 150,000km..... but its not a Mazda design fault, it's the line worker who got it wrong?
Sure.
So why did they change the design again?
Just when you thought it was safe.
Fletch wrote:Ha ha ha....Simple, the bolt isn't cast on the end of the crank is it?
Sure.
The engines are hand built by Mazda engine techs on engine assembly lines, machines and humans make mistakes otherwise us mechanics would'nt have to contend with WARRANTY CLAIMS.
Anyway here is some more damning evidence from the link below
*****Warning contains graphic crankshaft and keyway violence******
http://www.miataclub.org/orlando/94crank/
