Head Rest Spkr plugs wanted
Post by Ian » Fri Aug 07, 2009 10:51 pm
Hi...Am looking for a pair of the flat 6pin plugs which take the wires up to the headrest speakers ie the female plugs which connect to the plugs of the factory harness under the seats.
Ian :)
Post by sprsta » Sat Aug 08, 2009 1:10 pm
i have a set if you want them the speaker plugs have been cut off thoughthey are still in the seats so if you want them let me know and ill pull them out
Post by sprsta » Sat Aug 08, 2009 4:26 pm
i just had a look at my drivers side one and it is only a four pin plug that is square so probably wont fit if yours is flat with 6 pins (do you know what the other two pins are for?)
Post by Ian » Sat Aug 08, 2009 9:41 pm
Hi,,
Two of the pins are unused, but it needs to be a 6 pin plug to mate with my factory plug. (I could hardwire but need the correct plug so that I can easily swap in my Momo race seat when required).
I assume your pass seat is the same as drivers?
Post by brownie » Sun Aug 09, 2009 9:23 pm
Hi,
You've got something coming to you in mail for this,
The later 6 pin plug is for the facelift NA's that not only have headrest speakers but some cars also had 6" mid sub in the back of the seat.
If you go real well you can get a factory 10 speaker set in these cars !!.
Post by Ian » Sun Aug 09, 2009 11:26 pm
Mark...you are a hero!
Rear subs eh? Now there an idea! (not) :D
