1990 NA 13B ENGINE SWAP . Progress Pic
MX5 13B
Post by MX5 13B » Fri May 29, 2009 11:32 pm
Any one on the forum done this conversion .... :?:
Post by jif » Sat May 30, 2009 6:56 pm
dont think so, but you might wanna look up member nfs13b at aus-cartalk.com.au
Post by SLYDIT » Sun May 31, 2009 9:50 pm
Don at autoway services has done this conversion.
off the top of my head it required:
-New front engine subframe welded to the cross member.
gearbox was frankensteined with a mx5 rear and rx front housings.
-Firewall had some massaging to clear the engine.(crankshaft center sits higher in a rotary)
-low pressure fuel regulator for the carb
He had it for sale . maybe it still is?
MX5 13B
MX5 13B
Post by MX5 13B » Mon Jun 01, 2009 12:27 pm
I have a 1989 NA MX5. Will be building a 13B bridgeport engine.
The gearbox i am using is out of a 1994 FD RX7 with FC bellhousing.
I am using TII diff and half shaft. Will be running a 4 barrel nikki carburetor
and will go injection and turbo late next year.
Image[
MX5 13B
Post by MX5 13B » Sat Sep 19, 2009 6:32 pm
RX7 1991 diff into my NA
NA 1800 Brake upgrade.
MX5 13B
13B MX5
Post by MX5 13B » Mon Oct 05, 2009 9:19 pm
MX5 13B
13B MX5
Post by MX5 13B » Mon Oct 12, 2009 12:12 am
My daily driver .
12a MX5
Post by 12a MX5 » Thu Nov 26, 2009 7:00 pm
I am also doing a rotary conversion. How ever , I have gone with a Injected 12a.
Rotor Powered NA6
Anthug
Post by Anthug » Fri Nov 27, 2009 8:12 am
Nice.
What sort of diff are you using?
How much HP do you expect?
Anthony
MX5 13B
13B NA
Post by MX5 13B » Fri Nov 27, 2009 10:52 pm
Will post new pictures of car tomorrow. All running now .
12a MX5
Post by 12a MX5 » Sat Nov 28, 2009 3:40 pm
Any chance of putting up some pic of your engine mounts? I have mine mounted already but stikll like to see how others did it. And did you make a new gear box crossmember or some how intergrate the mx5 torsion bar?
Rotor Powered NA6
MX5 13B
new project NB 13B Rotary
Post by MX5 13B » Thu Nov 25, 2010 11:14 pm
i have a new rotary project. Its a NB that i have bought from MX5 Mart.
Users browsing this forum: No registered users and 63 guests
