Tyres - Asymmetrical vs Directional etc
Post by zorruno » Tue May 22, 2007 9:30 pm
They are more than directional - asymmetrical tyres have to go on the correct side... and mount the correct way around.
Which is a bummer... as there are fewer options for rotating them if they wear unevenly (my fronts wear on the insides, so I flip them over and swap sides after each few 1000 kms). Yes, I know I could fix the wear, but I like my current alignment.... ;)
simple
Toyo Proxes PX4 & Bridgestone Potenza Adrenalin RE001
Post by simple » Wed May 23, 2007 7:26 am
Close, but no cigar (as I understand it). Asymmetric tyres are not
necessarily directional. eg. Yokohama A539
http://www.yokohama.co.nz/a539.html
Which is a bummer... as there are fewer options for rotating them if they wear unevenly...
The A539 is actually just as 'rotatable' as any 'old-fashioned' tyre.
Once they have been mounted correctly on a rim (ie. with the outside of
the tread pattern toward the outside of the rim) then you can stick them
on any corner of the car. The tyres are (supposedly) equally happy
rotating in either direction, and they don't make lefts and rights.
You are presumably thinking of tyres which are asymmetric *and*
directional. The two aspects do not necessarily go together (even if
'common-sense' suggests they should).
Asymmetric tyres do limit your options if you're the sort of freak that
demounts the tyres from the rim and remounts them to swap the
inside/outside of the tread. Are you *that* sort of freak, zorruno?
Karl.
(PS. I've not done an exhaustive check of assymetric vs directional - it
really wouldn't suprise me if 99% of assymetric tyes were also
directional)
Shermio
Re: Toyo Proxes PX4 & Bridgestone Potenza Adrenalin RE00
Post by Shermio » Wed May 23, 2007 9:46 am
simple wrote: Asymmetric tyres do limit your options if you're the sort of freak that
Well I personally would not go as far as removing the tyres from the rim to rotate them cause that means I have to rebead them in... Im only a freak in that I wash the wheel wells... :oops:
Post by zorruno » Wed May 23, 2007 10:39 am
Yes, you are quite right, and looking further I see there are some other asymmetric tyres around that are not directional. They are also not as new a concept as I understood either. Asymmetric + Directional is what I suppose I was really meaning.
You know I am :) It helps knowing people with tyre machines though - and there is the fact that I don't do too many kms these days so I don't have to swap them often.
With the uneven wear, I do have to swap them over as regularly as possible to get a decent life out of them.
Post by zorruno » Wed May 23, 2007 12:55 pm
OK, some useful info on tyre selection and asymmetrical tyre treads (including from the ltsa...);
http://www.etyres.co.uk/glossary-tyre-t ... ymmetrical
http://www.tyres-online.co.uk/techinfo/patterns.asp
http://www.ltsa.govt.nz/factsheets/32.html
I'll move the last few posts to its own topic.
