STICKING LIFTERS,...was SYNTHETIC OIL?
GerryAttrick
Post by GerryAttrick » Tue May 08, 2007 10:09 am
Looks like the synthetic oil thread has widened to cover sticking lifters and oil pressure gauges so I thought maybe this deserves another thread?
For what its worth I had a Ford Explorer that had a sticky timing chain tensioner and sticking lifters. My neighbour - an AA mechanic suggested using one of the proprietary cleaners that you add to your oil (available from Repco & Supercheap) to save on an engine out job to replace one of the tensioners (it seems one is on the rear of the Explorer engine!!)
Anyhow I tried some and although it made things a bit better it did not solve the problem entirely.
ThenI remembered an oil thread on another site, posted by an oil company chemist,that said that oil for diesel engines was fine for petrol engines but was high in detergents so I grabbed a 4 litre pack, left the old filter on but drained the old oil and poured that fresh (diesel engine) oil into the engine in place of normal Mobil 1.
I ran it for about 200 kms and it was amazing the difference - the lifters stopped ticking and the tensioner pumped up straight away. My wife wanted to know what I had done to the Explorer as it was the quietest it had been since we bought it. I sold the Explorer shortly after with about 500km running on the oil for diesel engines and other than being real dark from all the crud that had been loosened it was running fine.
I told the new purchaser that it needed a new filter and fresh oil and why and he was quite happy to take it and do the change himself.
So if you are having trouble with sticking lifters then maybe you could try a drain and fill with engine oil for a diesel engine...its pretty high quality and I doubt would cause any problems other than maybe you will burn more oil if your compression is being maintained by all the carbon on the piston tops.
As always...you are on your own if you try this and it turns to custard.
NOTE: the oil is lubricant for diesel engines NOT diesel oil itself. :roll:
GerryAttrick
Post by jif » Tue May 08, 2007 5:21 pm
the "2twisty flush" is another choice - basically to use ATF (auto transmission fluid)
http://forum.miata.net/vb/showthread.ph ... isty+flush
... or kerosene is the other one, apparently it's the ingredient in most engine flushes.
Diesel engine oil is a new one! Having seen what happens to the oil in our turbo-diesel wagon tho, I ain't surprised... that stuff is f-i-l-t-h-y !!
Gerald Warner
Post by Gerald Warner » Wed May 09, 2007 10:18 am
I can attest to the validity of this also. I had a Falcon with noisy hydraulic lifters and my mechanic suggested I try a diesel oil. It had a remarkable efect and I never used anything else. As I understand it it is because the diesel engine oil has extra detergent in it.
Users browsing this forum: No registered users and 100 guests
