Battery, does an open boot turn on a light and drain it?
jolyon39
Post by jolyon39 » Thu May 18, 2006 10:03 am
Hi,
Well, I have had the car for 4 weeks and the battery in my 1989 MX seems to
have died. Do I have to use a special battery from Mazda?
Also, I left the boot open to dry out some moisture that got in around the
aerial. Does opening the boot turn on a light somewhere that could have
drained the battery. My car is an early 1989 model.
Regards,
Jolyon
Mazda perfected the Triumph TR7 experience
ianbell
Post by ianbell » Thu May 18, 2006 10:24 pm
Hi
You don't have to buy a Mazda battery but it is the best type of battery for
the MX5 for a number of reasons - the battery construction as well as the
limited ventilation available in the boot. The club discount at your Mazda
dealer helps. A normal battery can be used but is not as good. If the car is
left for more than 1 week or 2, it is not uncommon for an older battery to
go flat, especially if it has an alarm.
ian
CHN433
ianbell
Hi
ian
CHN433
Vince
Post by Vince » Fri May 19, 2006 6:05 am
If you have an alarm fitted, the interior lights are quite likely on when
the boot lid is up. Vince.
Vince
Return to “2006”
