I have just tried to open my driver's door from the inside and something has
broken. It cannot be opened using the inside or outside door handles. If I
take the plastic moulding off from around the inside handle I can see that the
metal rod still moves with the handle so perhaps the problem is at the door
catch end.
Has anyone experienced something similar? If so, any solutions would be most
appreciated, particularly, how can I open the door to take the inner liner off
to fix whatever is broken?
David Moughtin
From jifjif@gmail.com Fri Apr 27 17:56:46 2007
h=received:message-idfrom:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references;
b=Q83aJqk24Npt4Y7JF7VW/sraTlNCaWMjOmF/yHsXv8JLIlGGYp1lBNg6g5erzVBnaClKVIzG5jxpbBiGH42BB2PLWPuKRvubfFP+KuFVn4PTRHeLj9xA+74FupHVmyfPVWrlJPg3B2YNwbOw7M5Pk7CZyCLOZ0rql6PEEr9g4fo=
Date: Thu, 27 Apr 2006 23:07:35 +1200
Subject: Re: Door opening mechanism
In-Reply-To: <001001c669e6$d8b6efe0$0100000a@lan>
References: <001001c669e6$d8b6efe0$0100000a@lan>
Message-ID: <wL6jxC.A.HQH.bGZMGB@L733>
maybe a slimjim (not the biscuit!) or something similar? There's a
little lever near the B pillar that needs to be pushed... or pulled...
Yup, I know that one
There is a small spring that will be now be sitting inside the door. It has
either broken or fallen off.
If you can work out where it goes, you'll be fine.
_____
David Moughtin
Sent: Thursday, 27 April 2006 10:39 p.m.
To: MX5List
Subject: Door opening mechanism
the metal rod still moves with the handle so perhaps the problem is at the
door catch end.
off to fix whatever is broken?
David Moughtin
_____
David Moughtin
To: MX5List
door catch end.
David Moughtin
Users browsing this forum: No registered users and 89 guests
