Hio Gazza; You have worn hinges, a fairly common problem.You can mark
around the hinge with a pen onto the bonnet to get the outline of the hinge
before removing it.You will need to remove the top mudguard bolts and the
one behind the mudguard liner at the rear edge of it( you will need a long
extension and 10mm socket to reach it) to enable you to pull guard out to
access hinge fixing bolts.Used hinges are $40 + gst a pair which is
probably cheaper than trying to rebush them.Holding the bonnet and fitting
the hinge is a 2 person job.Ross.
Rattles? possibly from my bonnet.
