hi guys
my front pulley has got a wobble
is this a common fault on an older car or is it worth looking at a second
hand pulley?
do these puleys have a rubber center or something?
ta
howard tiddy
front pulley
front pulley
if your talking about the pulley on the crankshaft
then you may have the dreaded "short nose crank"
failure. The keyway that holds the pulley on becomes
worn due to bolt or crankshaft nose failure. Incorrect
installation of the key steel when getting a cambelt
done has sometimes caused this. Id get it looked at ASAP!!!
front pulley
do you know of any one in the waikato who's good at fixing this sort of thing?
ta
h
ta
h
front pulley
Re your wobbly front bit read this and associated links which are
mentioned.
http://www.miata.net/garage/hsue/LoctiteCrank1.html
Cheers Janet & Jeff
mentioned.
Cheers Janet & Jeff
front pulley
Don McLean at Autoway services is your best bet in
Hamilton. Infact Hes running an mx5 technical day this
saturday at 2pm so you should come along.
Glenn "SLYDIT"
Glenn "SLYDIT"
