Turbo kit on trademe (was Re: MX5 v Supra)
Post by zorruno » Sat Mar 27, 2004 9:46 am
Lou, theres a turbo kit for sale on trade me, starting price is 6500, is
that the sorta price one would expect to pay?
What make?
Lou
I was looking at trademe anyway, so I assume he means this
http://www.trademe.co.nz/structure/list ... 913005.htm
Text from auction below:
Mazda Mx5 Turbo Kit:
Bolt on turbo Kits for your ride :
Complete and easy to install ,
What to expect from AVOTurboworld Bolt-On Turbocharger Kits.
AVOTurboworld has been turbo charging motor vehicles for more than 30 years
so it's no surprise that we know exactly what it takes to make a high
quality turbo kit for maximum performance and reliability.
AVOTurboworld turbo kits use the highest quality components and
manufacturing
techniques available in the world.
AVOTurboworld kits are designed for minimal installation time and ease of
fitment.
For example, to help expedite the fitment process, we pre-assemble the
turbocharger
with the actuator assembly to the manifold and outlet casting.
All kits consist of:
Engine Management
Garrett ball bearing turbocharger with internal waste gate for
the best response and performance available.
Ni-Resist cast high flow turbo exhaust manifold.
Stainless steel manifold heat shield.
High temperature Inconel exhaust studs.
Cast turbo outlet & Mandrel bent stainless steel front pipe, which bolts
either to original factory cat converter or to original first muffler.
Bar and plate intercooler core with high flow cast aluminium tanks which
have been designed for maximum cooling efficiency and minimal pressure drop.
Intercooler pipe work in powder coated or chromed mandrel bent steel
and also Kevlar reinforced high-pressure high temperature rubber.
AVO dual intake power filter
Where required AVO Sequential Blow-Off Valve for
better response and turbocharger reliability.
High pressure silicon hose joiners
High quality stainless steel hose clamps
Also able to supply kits for most makes and models , Feel free to ask if one
is available for your Vehicle .
Free Freight New Zealand wide ,
Delivery time is about 1 week , Customer will always be informed on delivery
status
Free shipping in NZ
Girardin
Post by Girardin » Sat Mar 27, 2004 5:32 pm
AVO has a good name on the US lists, despite having limited support over
there. I'd investigate the cost of importing a new kit from Oz.
Lou
Gareth Kemeys
Post by Gareth Kemeys » Sat Mar 27, 2004 6:43 pm
Thankyou Lou, as always a valued opinion.
Return to “2004”
