changing manual gearbox oil
Peter F
Post by Peter F » Tue Jan 13, 2004 8:04 pm
Hi, Can anyone who has an mx5 manual tell me what is the correct type of oil
for a manual transmission and how much it takes? I've ordered a book via
amazon.com, but don't want to wait until then. It's a bit awkward putting in
the new oil too, I think.
My '91 has just reached 201,000km and has probably never had it changed.
Every 100,000km is the correct interval isn't it?
John Forsyth
Post by John Forsyth » Wed Jan 14, 2004 9:29 am
75W90 gear oil or Redline MTL.
2L (or 2 quarts) will leave a little over.
Recommended interval 30K miles say 50K km.
Instructions here -
http://www.miata.net/garage/trans/everything.html
__________________
john forsyth, BCG191
Kjellberg, Adrian
Post by Kjellberg, Adrian » Wed Jan 14, 2004 9:38 am
I put in Redline MTL (75w-90) and it is great. Need 2 qt's at $25 each.
Lyndon at the shop really knows his stuff. Worth asking about suspension as
well.
"Kendall Racing Supplies on Auckland's sunny North
Shore has RedLine ... ~$30/qt last time I looked.
TurboTinker runs the Redline MTL (75w-90), but will
try the heavier Redline MT (80w-90) next time. Or
Amsoil."
Adrian
Wayne
Post by Wayne » Wed Jan 14, 2004 5:32 pm
Hi, Shells listing (www.shell.co.nz) for the 5 speed gearbox is XGO 75/90
and takes 2.0Lt. Remove the gear lever to fill the box with oil. Most of the
oil companies have listings for most cars. Worth a look.
Wayne
Fletch
Post by Fletch » Thu Jan 15, 2004 7:26 am
You DO NOT remove the gear lever to change the oil... which manual have
you been reading?
If you dont own manual, most home-mechanic type jobs are well described,
with pictures, at www.miata.net/garage/
There is a fill plug on the passenger side of the gear box.(and a drain
plug underneath).
(The "turret" section of the gear box, where you remove the lever does need
lubrication, but it takes 90cc... no way you'll get 2 litres in there)
John Forsyth
Post by John Forsyth » Thu Jan 15, 2004 9:22 am
NO !!!
Filler plug is on side of gearbox next to exhaust pipe.
As well as refilling gearbox, you should remove gearlever and top up oil in
extension housing, same oil.
Again -
will show you how.
__________________
Wayne
Post by Wayne » Thu Jan 15, 2004 5:56 pm
Fletch
I stand corrected...if the extension housing has been removed you need
to fill it through the gear lever hole/position.
Wayne
Peter F
Post by Peter F » Fri Jan 16, 2004 11:54 am
Thanks, have changed the oil. The link to miata.net was especially useful.
Peter
Return to “2004”
