Hi Guys
I have a problem with the 1.8 in my 1990. If I leave the car for a
length of time 5 days or so it starts up on three with clouds of smoke -
does not smell like oil. Even in the morning it starts a bit rough but
with quite a bit of smoke. Clears on to four after a little bit. I'm
wondering if I have an injector problem? If one injector is leaking or
dripping would that cause this type of symptom? Secondly who in
Hamilton should look at it?
Update on the steamy interior - definitely the heater as When I lifted
the mat to clean the car tha driver's side carpet was soaked in coolant.
Bummer! I will bypass the heater until I have time to remove the dash
and get the beast repaired.
Don
Problem with the 1.8 Injector? Valve stem seal?
Take it to (Doctor) Don Mclean at Autoway Services in Frankton. He
specialises in MX5s.
Gordon.
Check out our website at http://www.tiptop.co.nz
Blast Away With The NEW Chill MEGABLAST. It's full of taste Explosions !!
CAUTION: This E-Mail message and accompanying data may contain
information that is confidential and subject to privilege. If you
are not the intended recipient, you are notified that any use,
dissemination, distribution or copying of this message or data is
prohibited. If you have received this E-Mail in error, please notify
ahelpdesk@tiptop.co.nz immediately and delete all material pertaining to this E-Mail.
This footnote also confirms that the above email has been scanned for the presence of known computer viruses as well as content considered unsuitable for transmission.
Gordon.
Lou no longer at this email address. Pls delete from your addy list.
Booked in for WednesdayGood advice
Don
Users browsing this forum: No registered users and 96 guests
