Hi Guys
Thanks for the feedback on the brakes. I ended up getting a replacement
calliper from Ross. The important difference was that the adjuster
worked and the area where the adjuster is situated in the calliper was
dry. Mine was full of brake fluid and the adjuster was so stiff I ended
up stripping the teeth off the geared adjuster while trying to get the
thing to work. The piston was fine in my calliper so I will keep all of
the old bits in case I end up with a corroded calliper in the future.
I will replace all of the fluid in my system as a maintenance procedure.
Anybody got a good reference to this process?
Don
Rear brake calliper problems
It's easiest to do with 2 people, one pumps the brakes and keeps the reservoir
topped up, the other opens the bleed nipples. Attach a clear hose to the left
rear nipple, run the other end into a jar with about 20 mm of fluid in the
bottom. Open the nipple and pump approx 300 mil of fluid through to flush the
system. Close this nipple, then do the right rear, left front, right front in
sequence. You'll need less fluid to flush the front lines.
For Brake Pad replacement... http://ww
w.sandiegomiataclub.org/SDMC/Garage/Brake_Pads.html For Brake Bleeding...
http://w ww.sandiegomiataclub.org/SDMC/Garage/Brake_Fluid.html For these
and other articles in an index... http://www.sandiegom
iataclub.org/SDMC/Garage.html On Sun, 22 Jun 2003 18:59:50 +1200, Don
Mikkelsen wrote: Hi Guys
Don
Don
