Hi, looking for supplier of a check valve to insert in the 1/2"line between my air intake on my supercharger and the air inlet on the dummy throttle body - supposed to get an extra 1/2 psi boost .
Any help ?
Grant
SC
SC
"Hose supplies" has them as well. You can get brass
spring loaded check valves very cheaply, just check
that the spring is not too stiff. if it is then you
can simply unscrew the two halves and cut the spring
slightly to make it more forgiving.
Glenn
--- rotarypower <rotarypower@value.net.nz> wrote: >
ash air has them on the shore >glenn munro
Glenn
-----------------------------------------------------------------------Grant Schou wrote:
insert in the 1/2"line between my air intake on myHi, looking for supplier of a check valve to
body - supposed to get an extra 1/2 psi boost .Any help ?
Grant
-----------------------------------------------------------------------you have received thisThis email contains confidential information. Ifinform us of the mistakeemail in error, please delete it immediately, andfurther dissemination ofby return email. Any form of reproduction, oremail are those of thethis email is strictly prohibited.
Also, note that the opinions expressed in thisFonterra Co-operative Groupauthor and are not necessarily those of the
