I've never liked those holder thingys - I've use spray contact adhesive glue
for the last few years. Looks better - takes up less window room - and can
never blow away.
1. clean inside window thoroughly with alcohol or window cleaner
2. give label a good spray (on writing side...)
3. allow to dry until tacky
4. stick to window and rub with cloth until smooth.
You can rip it off to remove it when necessary, clean the window again and
stick the new one on. A couple of strips of wide double sided adhesive tape
works almost as well
h+c+z
holder for registration label (was Re: $200.00 fine)
Users browsing this forum: No registered users and 75 guests
