went to back the car last night, and couldn't. No reverse gear at all! No graunching sounds, selector works fine in all
forward gears, clutch fluid reservoir full & fresh, clutch depresses fully to the floor when required, forward gears
change smoothly when mobile or static.
Does anyone have any ideas/tips?
Peter
DRGN1
No Reverse Gear
No Reverse Gear
Pop over to the garage section of Miata.net
Getting stuck in reverse is a semi common problem, and a road-side fix
is listed.
Your fault may be related, and it certainly cant hurt to read up on
how to fix it...
Good luck,
is listed.
how to fix it...
Good luck,
No Reverse Gear
http://www.miata.net/garage/stuckreverse.html
just in case you couldn't be bothered searching...
cheers H
cheers H
