instrument cluster illumination resistor
Phil Dyer
Post by Phil Dyer » Tue Nov 20, 2001 9:55 pm
Found the fog lights switch ($30 ouch!) and works great.
Does the 323 have the instrument cluster illumination resistor switch?
Phil
carl.halvorsen
Post by carl.halvorsen » Thu Nov 22, 2001 7:34 pm
Phil,
The 323 resistor is completly different. I tried that. I bought a MX5 one from
the dealer. I have the part number somewhere if you want it.
carl
Nigel Every
Post by Nigel Every » Thu Nov 22, 2001 10:12 pm
Carl, the one I got was out of a NZ New 1992 323GLX and fitted straight in with no
problems at all.
Phil,
The 323 resistor is completly different. I tried that. I bought a MX5 >one from
Phil Dyer
Post by Phil Dyer » Fri Nov 23, 2001 6:52 am
Carl
Was passing a wrecker yesterday and picked up one. It's a long switch! Dont
know what is inside but I can see quite a bit of electronic parts. Anyway
works well, but cost $39 inc GST.
Phil
From MattGunn@newstalkzb.co.nz Fri Apr 27 15:48:19 2007
Subject: RE: floppy springs...
Date: Fri, 23 Nov 2001 06:57:40 +1300
Thread-Topic: floppy springs...
Thread-Index: AcFzIR4OcWZmZDvNTmi0QmMocH/9jQAJMeWg
Message-ID: <QDvGVD.A.9R.CVXMGB@L733>
I TEND TO AGREE WITH FLETCH ON THIS ONE. BACK TRACK TO THE PLACE OF
PURCHASE. I WOULD ASSUME THE CAR WAS WARRANTED WHEN YOU PAID FOR IT.
MISLEADING INFORMATION AT THE TIME OF SALE IS ILLEGAL. THEY SHOULD FIX
THE PROBLEM. MY UNDERSTANDING IS THAT IT DOESN'T MATTER HOW LONG YOU
HAVE HAD THE CAR , OR HOW MANY TIMES IT'S BEEN PASSED. THE ONLY PROBLEM
YOU MAY HAVE IS PROVING THAT THE WORK WAS NOT DONE BY YOURSELF . THIS
COULD BE A STICKING POINT. HOW DO YOU PROVE IT WAS LIKE THAT WHEN YOU
BOUGHT IT SINCE IT HAS BEEN PASSED ???
LET US KNOW HOW YOU GET ON.
CHEERS
MADMXV
P.S - STILL WONDERING IF $650 + GST + 2 HOURS LABOUR FOR A DIFF REBUILD
IS OK. AND WHAT IS IT THAT GOES WRONG WITH THE LIMITED SLIP DIFFS ON THE
CARS ???
carl.halvorsen
Post by carl.halvorsen » Sat Nov 24, 2001 5:51 am
Luck Phil,
The resistor I tried must of been from an earlier 323. Your car is almost
complete now?
Carl
Phil Dyer
Post by Phil Dyer » Sat Nov 24, 2001 8:21 am
Well it has the gap for a rear window demiser switch and I can get on for $20,
but have only a soft top...wondering what I can use that for?
Why dont the fit the instrument cluster illumination resistor as standard?
What difference would braces make to ordinary road handling?
Phil
From MattGunn@newstalkzb.co.nz Fri Apr 27 15:47:43 2007
Date: Sat, 24 Nov 2001 09:38:27 +1300
Thread-Index: AcFznc8iC5uOVJtmSZ2xdKDVo6HaKQAiOlzQ
Message-ID: <69R-eD.A.HS.CVXMGB@L733>
hi gary
It is a viscous LSD. The word from the guy was this. diff $650 plus gst.
2 hours labour at i think around 55 dollars an hour. I havnt spoken to
the guy since your email but from previous info I'm thinking its $720
ish for the diff plus labour. I will be checking prices , in the
meantime anyone with an idea of what would be acceptable , please let me
know.
MADMXV
Return to “2001”
