HI TH ERE FOLKS... QUESTION TIME... WE BOUGHT OUR LOVELY LITTLE 89
ALL ORIGINAL 5 A MONTH OR SO AGO. WE LOVE IT... BUT,,,, IS THERE A
WAY OF TELLING IF THE TIMING BELT HAS BEEN DONE OR NOT. SOME VEHICLES HAVE
AN INSPECTION PLATE THAT LETS YOU SEE,,,, SO DOES ANYONE KNOW DOES THE MX5
HAVE ONE?? OR IS THERE A DUMMMIES WAY OF TELLING.
I PRESUME IT HAS BEEN DONE ONCE, BUT WONT BE THAT LONG BEFORE IT NEEDS IT
AGAIN,, SO THOUGHT WE MITE DO IT IF IT WAS LOOKING LIKE IT NEEDED IT.
ANY SUGGESTIONS?
R. & R.
Timing Belt
Timing Belt
Woah settle down no need to yell !
Check your service book, most owners make sure it gets stamped
especially with something as expensive as a timing belt change.
- Dave
- Dave
Timing Belt
If you are in Auckland, there is a technical day end of this month that would be worth attending to find out all about these sort of questions.Hi Robyn & Rich. No there is not an inspection cover as such. You need to take the rocker cover off to have a look at the belt. Milage travelled is only one aspect to the timing belt needing to be changed. As it is a rubber compound it will deteriorate with age etc anyway. Also the tension pulleys may need to be replaced depending on the condition of them. It is a job you can do yourself if you have a reasonable mechanical knowledge.
Nigel
HI TH ERE FOLKS... QUESTION TIME... WE BOUGHT OUR LOVELY LITTLEFrom: "Robyn and Rich" <glassone@xtra.co.nz>
Date: 2005/07/07 Thu PM 12:30:23 GMT+12:00
Subject: Timing Belt
ANY SUGGESTIONS?
R. & R.
89 ALL ORIGINAL 5 A MONTH OR SO AGO. WE LOVE IT... BUT,,,, IS
THERE A WAY OF TELLING IF THE TIMING BELT HAS BEEN DONE OR NOT. SOME
VEHICLES HAVE AN INSPECTION PLATE THAT LETS YOU SEE,,,, SO DOES ANYONE
KNOW DOES THE MX5 HAVE ONE?? OR IS THERE A DUMMMIES WAY OF TELLING.I
AGAIN,, SO THOUGHT WE MITE DO IT IF IT WAS LOOKING LIKE IT NEEDED IT.ANY
SUGGESTIONS?R. & R.
Timing Belt
Hi
If you remove the cam cover you will be able to inspect the timing belt.
I'm not sure if that will be very helpful as they look OK up until about
50km from breaking. My advice is to replace if you are worried as the
inconvenience of it breaking will be a hassle. The standard engine will not
do itself harm as the valves do not open far enough to interfere with the
pistons.
Don
_____
nigel.e@xtra.co.nz
Sent: Thursday, 7 July 2005 2:31 p.m.
To: MX5List
Subject: Re: Timing Belt
ANY SUGGESTIONS?
R. & R.
pistons.
Don
_____
nigel.e@xtra.co.nz
To: MX5List
ANY SUGGESTIONS?
R. & R.
