Smart ideas for fitting a wind blocker ?
GEEMCB
Post by GEEMCB » Mon Jul 04, 2005 8:13 pm
Greetings, all
Some bright ideas would be appreciated ... I'm trying to find a way to
attach a polycarbonate sheet (aka wind blocker) within the large single-hoop
style bar adorning my car.
I'd really like to be able to attach it so that the 50mm chromed tubing
frames the polycarbonate - this means finding a way to attach the sheet like
so ...
O
O
The alternative is to use some marine canopy clips & attach to the rear of
the tubing like so ...
O|
O|
Not as neat, but potentially easier to do.
Any ingenious ideas out there on how to achieve the top option? (without
having to weld tabs to the bar & rechrome - ouch $$$ !!!)
Regards,
Greg
1990 V Special
Greg
1990 V Special
KSCRIM
Post by KSCRIM » Mon Jul 04, 2005 8:43 pm
4 small holes and 4 white cable ties???
Kevin
EricW
Post by EricW » Mon Jul 04, 2005 8:58 pm
Greg,
Don't know if this works for you, but could you get some 50mm ID
polycarbonate tube and split it, thus forming a "C" section channel, to be
glued onto the edges of the wind blocker and then the whole thing slid
between the hoops, with the C sections sitting round the hoop and the wind
blocker sitting centrally between them. You might have to put a flat on the
outside of the pipe to get a good bonding surface with the edgeof the
polycarbonate sheet
I will try to draw what I have in mind
O)---------(O
Just an idea, but it might work
Matt & Sarah Avery
Post by Matt & Sarah Avery » Mon Jul 04, 2005 10:09 pm
For my windblocker I had it laser cut to size, complete with several
slots around the edges (& mazdaspeed logo). I bought some rubber edging
to tidy up the perimeter and attached it to my twin hoop bars with Black
Velcro cable straps.
There is a picture here on my site (I think this link works - my
connection keeps crashing!!)
http://miata.cardomain.com/ride/241633/3
r.v.boxall
Post by r.v.boxall » Tue Jul 05, 2005 10:11 pm
Greg,
Cut some slots in the polycarbonate, and loop some velcro straps round the bar, and through the slots. Works great on mine!
Ron Boxall, 1991 BRG V-Special, MYATA
Return to “2005”
