Well after decididing to replace the brake pads ive
discovered that one caliper is leaking from the
adjuster and the other is jamming up every now and
then! AAARGH!!
Ive tried the usual sources for some second hand
replacements with no help, so i guess a rebuild is in
the works.. Any one had it done, and if so what was
done and how much was it???
(looks like another hurdle on the way to turbo nirvana
as the toy budget gets a hit.)
Glenn "SLYDIT"
Rear caliper rebuild...how much??
Hi, dont know where you are but im in welly and i found a guy down here with
parts a few weeks back so if you want used i can probably organise for you.
Alternately ring your local mazda agent and price a kit or 2.
Garry
Garry
