Fitting Towbar
Fitting Towbar
I'm seeking advice about fitting a towbar to an MX5. Being Wellington based
we spend time over in the Wairarapa cycling and wish to gain the double
benefits of travelling in the car and taking our bikes. Has anyone fitted a
towbar for carrying light loadings like bikes to an MX5 that is light weight
and non obtrusive. I suspect we will need to have to manufactured. I have not
checked out the LSTA guidelines but believe their rules will be designed for
heavier loadings than cycles. Can one get exemptions?
Any advice, experience and guidance greatly appreciated.
Tony
Tony
Fitting Towbar
Hi Tony,
The simplest way is to just go to a place that does towbars and have one
fitted, it will comply automatically and probably carry more than you will
ever put on it.
I dont know about pricing, but there used to be places for around the $200
mark here in welly.
Garry
ever put on it.
mark here in welly.
Garry
Fitting Towbar
Hi Tony,
ever put on it.
mark here in welly.
Garry
ever put on it.
mark here in welly.
Garry
Fitting Towbar
an alternative to a towbar?
<http://www.mx5parts.co.uk/product_info. ... cts_id/679>
-- Regards Terry
So many cats. So few recipes.
-- Regards Terry
-Terry
-Terry
Fitting Towbar
-- Regards Terry
-- Regards Terry
-Terry
-Terry
Fitting Towbar
I have seen similar racks here. A neighbour in the Hutt used to have one on
his MR2. It was a clip on that fitted to the edge of the boot lid.
From jifjif@gmail.com Fri Apr 27 17:03:00 2007
h=received:message-id
from:reply-to:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references;
b=Icnvmc84D/VV+OJXv3vHnE8OGTytoAdR30ETxB4eiZFFFYkI2ZoH8IxNeJHogPCTvm8x3j/dOUKUFZJAyx8+bREIJvYP6/CvSGoTAp81pQVSePcz4Z9t1CWtDOCLIxua13o9BqFoHYkbvYroUiCJgatM1ll7e1lsD8hC66G7xmg=
Date: Thu, 26 May 2005 22:20:07 +1200
Subject: Re: Fitting Towbar
In-Reply-To: <NHBBIBJFKLGCMLFONCBEEEBACGAA.euen.burke@xtra.co.nz>
Mime-Version: 1.0
References: <LOBBKELMOEIIHOENFNNJCEHEGMAA.mx5-nz@lythehillpark.com>
Message-ID: <FvpWS.A.i7.UdYMGB@L733>
I have one - it's a bar welded to the 2 rear tow hooks. Just the thing
for fetching building supplies
Mime-Version: 1.0
Fitting Towbar
Mime-Version: 1.0
Mime-Version: 1.0
Fitting Towbar
The MX5 does not have any towing hooks, they are tie down hooks for shipping
only. The lightweight structure of the car was never intended to have any
weight towed by it. Good way to get an extra few inches in length though!!
From jifjif@gmail.com Fri Apr 27 17:02:58 2007
b=nF4GR2imdMFU68QpPINrq5TxPNTNY46ATL0psURDlcM3XXaNlY2vcW1s/3Y5NBdKLjLdJgpmygLHIPy7qVVmTP1iWaiFy3RPO8sCq70IinmdRM8Y5IKa6lG1z+n7e6gvS1Za6UYG5eAalhreqvEB1+W0TwZSdGwkyrTsQgNzsIc=
Date: Fri, 27 May 2005 08:07:09 +1200
Subject: Re: Colour (fastest)
In-Reply-To: <01ef01c56216$cb1cec00$a84f65da@PC446628134234>
Mime-Version: 1.0
References: <002c01c561d1$4d6faa30$0301010a@oemuvenry0wbi0>
Message-ID: <KuLqIC.A.l7.UdYMGB@L733>
fastest one I've been in is Satellite Blue
Mime-Version: 1.0
Fitting Towbar
Mime-Version: 1.0
Mime-Version: 1.0
Fitting Towbar
We had this discussion last year about the towing/tie down
hooks and the consensus was that it's pretty well urban
legend about the hooks being for tie down proposes only. And
wasn't it your old car Nigel that was lifted up by it's
front hooks and no harm done?? I recall you showed me a
photo. Your first MX5 I believe??
"PO1SON"
"PO1SON"
trailer&hl=en&lr=&sa=N&tab=wi
Fitting Towbar
"PO1SON"
"PO1SON"
Fitting Towbar
Gavin
When I asked this question a few months back, someone advised they got
one from Eastern Engineering in Taita (I think they are on Eastern Hutt
Rd just north of Wingate). I recall they said about $200 - 300 fitted
and wired.
Regarding bike rack only facility rather than towing trailers, you
could get a lighter one made that had a fixed fitting that your bike
rack attaches to (a simple cylinder of appropriate size with a machined
groove around for the bike rack bolt to locate and stop it
bouncing/lifting off) but a trailer coupling won't fit. Although I
would guess getting a one-off designed and built may be more expensive
than their existing standard MX5 tow bar design.
Let me know how you get on as when we sell the sedan we will be MX5
only and need ability for carrying our mountain bikes and maybe towing a
light trailer.
Ian Chapman
and wired.
light trailer.
Ian Chapman
Fitting Towbar
Gavin
and wired.
light trailer.
Ian Chapman
and wired.
light trailer.
Ian Chapman
Fitting Towbar
Hi Gazza, not my car, 1st or any others!! I take them off straight away and fit a grill to stop those nasties going into the radiator.
Date: 2005/05/27 Fri AM 11:14:14 GMT+12:00
To: MX5List<mx5list@mx5club.org.nz>
"PO1SON"
Fitting Towbar
"PO1SON"
trailer&hl=en&lr=&sa=N&tab=wiOn 5/27/05, Nigel Every <nigel.e@xtra.co.nz> wrote:The MX5 does not have any towing hooks, they are tie
intended to have any weight towed by it. Good way to
Fitting Towbar
Didn't Bill from Flyin Miata used to tow a U-Haul trailer to various
trade motor shows with all of his wares behind one of his first 'Turbo
Hacks'? I recall reading that he covered many miles towing the extra
weight and 'air-brake' effect of a big covered trailer. No mention of
whether he had to add a couple of extra doors after 50,000 miles!
Fitting Towbar
Fitting Towbar
Oh sorry Nigel, thought it was you . I recall someone
showing me a photo of the MX5 they won (or got very cheap)
from a fund raiser and it was held up on a crane from the
front.
"PO1SON"
From jifjif@gmail.com Fri Apr 27 17:02:49 2007
b=tLL+GwTmTF4npczFyajYOf5g3YXdcBnsIQEB4Q1OgYok3qF/elTBO7pErvkrh/eZ6lkF+MagqC5la8gpONVx0TeX+7/KntXBy63GXM/++tXd0Ue5RV20kD2GP7mJdtFsNVbwpat/tZqwojX8IvdvjONF5n3vjqjhhiRhaM3hTTU=
Date: Fri, 27 May 2005 12:09:08 +1200
In-Reply-To: <s29706f9.078@ngc.co.nz>
Mime-Version: 1.0
References: <s29706f9.078@ngc.co.nz>
Message-ID: <TTSfo.A.y7.UdYMGB@L733>
yeah, I was looking for that pic but it seems to be gone from their
site. I seem to remember Keith saying something about some scary
experiences with the "cart wanting to pass the horse" while driving
thru the Rockies...
Not the same as slinging a coupla mountain bikes on the back, obviously !
front.
"PO1SON"
Mime-Version: 1.0
thru the Rockies...
Fitting Towbar
front.
"PO1SON"
Mime-Version: 1.0
thru the Rockies...
front.
"PO1SON"
Mime-Version: 1.0
thru the Rockies...
Fitting Towbar
Just a word of warning on bike racks. The revenue collectors are starting to take more of an interest and are booking people for obstructing their rear number plates with bikes on racks.
Just another way of keeping their customer contact numbers up and contributing to Cullen's treasure chest.
Fitting Towbar
