hardtop & Car stereo
Post by poison » Wed May 25, 2005 8:08 pm
Good point Carl, but it always stirs up some fun, mind you you're probably
lucky, if your BRG is wearing a bit thin then it's the perfect time to paint
it decent colour... oops out loud...
Good article about the stereo wiring David... but the brake brace... now
let me think... " I took Gazza's s! uggestion and welded a triangle-shaped
gussett piece" (sic) ((see zorruno, got to use it already, sorry folks
private joke))... Anyway since when did 'suggestion' when looked up in the
dictionary mean 'COPY' :-)
And also zorruno's point about the earth on the light circuit is very valid
indeed, I must confess to having connected to that one more than once in the
various cars. But at least now I know to test first with a meter, I even had
one on my Celica that didn't become live until the lights and ignition were
on together, how strange is that. In the end it turned out to be a signal to
the "lights are on but car not running" Japanese Voice from the computer.
Boy, Really Green with Envy... NOT!
DBM58
Post by DBM58 » Thu May 26, 2005 12:46 pm
Ooops, I did it again ...
I thought it was quite clear, I took (stole) your suggestion. Does that not imply a certain amount of copying? Just as, for example, if I were to make a suggestion that said brace be powder-coated matt black and someone else where then to copy my suggestion and have their brace coated as well.
By the way, I do have a brake cylinder brace that has had value added by being coated black. I would be prepared to swap this brace shaped layer of black for a something of equal value.
David
DBM58
David
Mike Jolley
Post by Mike Jolley » Thu May 26, 2005 8:58 pm
do you have one for sale??? mike
Mike Jolley
Return to “2005”
