Hi all
Does anyone know the thread used on the temperature guage sender unit.
Temperature Sender
Temperature Sender
Temperature Sender
If you are thinking of replacing it with an after market one, I have read
that on the mk1 it also sends a signal to the ecu. So unless the replacment
works the same you could upset your cold start, and fuel mix. So I think
you need to keep the oem one as well. If you are wanting the size for puttin
in a T sorry, no idea.
I left my oem one alone cut the top radiator hose and fitted in the adaptor
for a temp sender from autogaue. I think it was about $25.
I picked it up at an auto shop (road&track in lower hutt) most places that
stock auto gauge could order one for you - or they sell them on trademe for
about the same price (or a bt more)
It it called a T3.
if you go to this site and go to products, advanced search, and look for a
T3 it will show them. unfortunatly the right size only comes in blue (i
think)
http://www.autogauge.com.tw
Sorry if this is not related to your question.
Mike va
It it called a T3.
think)
Mike va
Temperature Sender
It it called a T3.
think)
Mike va
It it called a T3.
think)
Mike va
