chroming (or chromed) mirrors - Anyone know where to buy bu
Post by poison » Sun Apr 24, 2005 11:58 am
I'd pay a hundy rather than do that again, the back is a breeze but the front
was just messy. Had a test drive today round the Albany industrial area, I had
been "ZOOM1N" (as Biff would say) around some corners and had got the balance
about right, then found some bumpy roads and did the same, didn't take long to
work out when the setting is too hard. There's 2 1/2 turns full range and even
half a turn is noticeable.
In the latest mag Dr Don talked about the sway bar bushes, mine were fine in
the links but the D clamps bushes were a little worn, although 1 mm play at
the clamp would probably equal about 3-4mm at the ends. So I'll replace those.
Has anyone changed theirs? and where did you get them?
"PO1SON"
Return to “2005”
