Oil feed and Tapping for oil return
Miatamad
Post by Miatamad » Mon Jul 24, 2006 11:58 am
Anyone (SLYDIT?), here who has tapped their oil pan for a turbo oil return - What sizes did you use?
Also what did you use for the oil feed? (any part #'s would be a godsend)
Chris
Post by poison » Mon Jul 24, 2006 6:26 pm
Hey Chris
Mine is fed into the dip stick at the base, I thought it a bit strange but this is what is reccomended in the kit. I must admit if I ever pull out the engine I will change it to the sump as I am worried about flow restrictions.
Post by SLYDIT » Mon Jul 24, 2006 8:26 pm
I used a 5/8th hose barb with a 5/8th bsp thread and tap. Get ready for the price of these suckers as they arent cheap at all, especially when you have to buy the drill bit too. ill get back to you on the exact sizes just to be 100% sure though.
mx5mike
Post by mx5mike » Tue Jul 25, 2006 9:15 am
I used the drill and tap that came with the FM Kit.  You are welcolm to borrow them if you can get the same fitting.  Check out the FM Website, they should have the part number or size there.
Mike.
[Posted via External Email]
Miatamad
Post by Miatamad » Tue Jul 25, 2006 10:48 am
Thanks Mike - You have a PM.
