by 4A-GE » Fri Oct 31, 2014 5:45 pm
Problem: I have a nice nardi knob except the wood bit spins freely on the aluminium bit that screws onto the gearstick. This is annoying because I hate stuff that moves when it shouldn't and it also makes an awful noise.
How the beep do I fix it? Does the aluminium insert come out of the wood bit or am I stuck with dumping glue into it until it stops moving?
Pun absolutely intended.
send help
by SkilletKid » Sat Nov 01, 2014 12:32 am
Mine had a set screw that you can use to tighten the knob onto the actual shifter. I'll see if I can find it.
by 4A-GE » Sat Nov 01, 2014 1:17 am
Mine has that. Aluminium bit tightens onto the stick just fine, but the wood bit twists and squeals.
by SLYDIT » Sat Nov 01, 2014 6:48 pm
keep twisting and pull at the same time? then glue it back on with epoxy??
by 4A-GE » Sat Nov 01, 2014 6:59 pm
Twisting and pulling? Oh my.
Nah yeah that's next on the list
by SLYDIT » Sat Nov 01, 2014 7:42 pm
didnt ya mum tell you//if you twist and pull ya knob it will eventually fall off. LOL
by 4A-GE » Sat Nov 01, 2014 7:44 pm
Aaaaaaand there's the dick joke.
