by BRM » Wed Jul 31, 2013 1:58 pm
My fans don't turn on at all..
I'm no sparky..
and im lazy.
first place were to look?
by chris » Wed Jul 31, 2013 2:03 pm
Fuse box.
Triple checked they are all hooked up?
Next thing get a voltage meter thing and check if you're getting any power from the outlet plug thingy.
by BRM » Wed Jul 31, 2013 2:04 pm
I HAVE TO LIFT THE BONNET?!
They can stay not working then.
by chris » Wed Jul 31, 2013 2:07 pm
I know. It's such a bitch of a task right?
Once the e30 is gone I'll pop over
by BRM » Wed Jul 31, 2013 2:08 pm
When is that gone?
Will you fix my fans for me?
by chris » Wed Jul 31, 2013 2:11 pm
Hopefully very shortly, and I will do my best, first thing is to make sure they are getting power.
I will leave any soldering up to you.
by marcellarius » Wed Jul 31, 2013 6:07 pm
Have you tried the diagnostic mode test?
Put jumper wire between the TEN and GND connectors in the diagnostic port, turn the ignition to "ON" and press the throttle pedal. Both the radiator and A/C fans should turn on.
