MX5 LSD problem??
MX5 LSD problem??
Post by Skilfil » Thu Oct 25, 2012 8:07 pm
Hey guys,
Got my blue MX5 and lately have noticed that when I take off from a turn even slowly the inside tyre chirps a little bit like I'm dropping the clutch a little quick.
But it happens even when I move off slow as I can.. Is that a problem with the diff? It works fine by the way..
Post by Furai » Thu Oct 25, 2012 8:08 pm
Do you know what kind of diff it is? Also is your car a 1.8, NA or NB?
Post by Skilfil » Thu Oct 25, 2012 8:12 pm
Doh, should've said.
1.6 NA, 1990. It still spins both rears and works great, just aside from that little niggle.
Edit: Not saying I've been ripping hectic skids, spun it up on the jack and worked.
Also on the rear seems to be staggered fitment. 185/50/14 front, 195/50/14 rear. I'd prefer standard size all around.. My red one felt much more balanced with all equal tyres (Same engine/diff)
Post by Furai » Thu Oct 25, 2012 8:27 pm
Do you have good tyres on? Sounds like it has a tight 1.5 way in it...
Post by Skilfil » Thu Oct 25, 2012 8:33 pm
Rears are Pirelli P6000s with LOTS of tread. Its got nearly 240,000 on the clock but the previous owner babied the hell out of it. Maybe he replaced the diff at some stage?
I was thinking a tight diff, but assumed from the mileage it shouldn't be that good.
Post by Furai » Thu Oct 25, 2012 8:34 pm
Its hard to tell but if its chirping the tyres it would have to be a good tight LSD.
Post by Skilfil » Thu Oct 25, 2012 8:38 pm
I'll have to take it to the Hampton Downs skid pan sometime then, my red one had a good diff untill it had to deal with wet slippery tarmac and it lost its shit.
Post by Furai » Thu Oct 25, 2012 9:15 pm
Theres a day this Sunday if your keen.
Post by chris » Fri Oct 26, 2012 9:11 am
Kieran is a very very lonely, lost child, He would love to have someone join him!
dynofiend
Post by dynofiend » Fri Oct 26, 2012 1:20 pm
I thought that early NAs only came with the VLSD as standard, and this is nowhere near good enough to lock the axle as you describe. In fact the VLSD is all but useless for anything other than driving on snow.
Must be a very tight retro fitted item?
Post by Skilfil » Sat Oct 27, 2012 1:09 am
dynofiend wrote:I thought that early NAs only came with the VLSD as standard, and this is nowhere near good enough to lock the axle as you describe. In fact the VLSD is all but useless for anything other than driving on snow.
I'm always told they're useless, I had a 1990 before this current one which worked fine as well except for one day on a wet skid pan it just spun one wheel. Certainly didn't do what this one does though when taking off.
Well I'm hoping to turbo it at some point so bonus points if the diff is good for it :D
Might actually ask the previous owner if he knows anything about the diff too, is there anyway I'd be able to tell when I lift it up and have a look?
Post by Furai » Sat Oct 27, 2012 7:20 am
Skilfil wrote:I'm always told they're useless, I had a 1990 before this current one which worked fine as well except for one day on a wet skid pan it just spun one wheel. Certainly didn't do what this one does though when taking off.
If its been fitted with a 1.8 Torsen it will have a rubber damper on the output to the driveshaft.
Problem is it sounds like a mechanical clutch type which some slot into the 1.6 housing. Possible try jacking up the rear and spinning one side at a time, I believe they should spin the same way no matter which wheel/direction
Post by CordedBowl » Sat Oct 27, 2012 9:16 am
Anyone know the details about hampton downs on sunday? Would be keen to have a blat around on the skidpad, but I'm not sure if I need to sign up etc?
Post by Angreal » Sat Oct 27, 2012 9:45 am
CordedBowl wrote:Anyone know the details about hampton downs on sunday? Would be keen to have a blat around on the skidpad, but I'm not sure if I need to sign up etc?
Just turn up on the day with some money and go to the shed and sign up :D
Post by CordedBowl » Sat Oct 27, 2012 10:40 am
Oh awesome! I'm definitely gonna rock up :D any idea on how much it is? Never been before!
Post by Angreal » Sat Oct 27, 2012 1:56 pm
I think it was $30 or $40
Post by Furai » Sat Oct 27, 2012 2:42 pm
CordedBowl wrote:Oh awesome! I'm definitely gonna rock up :D any idea on how much it is? Never been before!
Scroll down a bit viewtopic.php?t=10390 :lol:
Post by Angreal » Sat Oct 27, 2012 2:49 pm
Direct link :wink:
http://www.hamptondowns.com/event/56/20 ... LLENGE.htm
Post by CordedBowl » Sat Oct 27, 2012 3:01 pm
Thanks for the links guys :], I'll definitely be there to have a blast. Come say hi if you see me!
