Ebay, Trademe, Yahoo Auction Finds
Going to attempt to re-black my front lip at some stage, as well as various other small things that're bugging me.
The wheels also need a tidy up, but it's probably easier (read: more economical) to buy nicer wheels in good nick than it is to clean up the old ones... Unless there's a solution you lot are hiding from me.
Welp, onto the wishlist it goes.
have a nosey at this thread as repainting rims is pretty easy...
viewtopic.php?t=10666
I spent this afternoon mucking around with some aluminum trying to make one of those wind deflector thingy's the screw onto the drivers side window wiper.
Yup, i have 1 set left in stockMrGrey wrote:do you have the smoked lenses broomfish?
http://www.broomfish.co.nz/product_info ... ts_id=1657
Wish they made these badboys in a 16" diameter:
http://www.good-win-racing.com/Mazda-Pe ... -1388.html
Am very tempted to get a set anyway. Flow formed at 12.2lbs / 5.5kg for 15x9 +35. $159 usd each.
Will 15 look too small on an NB?
(from my reading) I thought 9" was a much faster set up than the same tyres on a 7" or 8"? 225/45/15s seem to be the fave tyre combo along with 15x9s in the States since it puts the sidewall of the tyre closer to perpendicular with the wheel.marcellarius wrote:15" is the right sizeIMO 9" is too wide. Unless you're going for a particular aesthetic appearance then closer to 7" will cause less issues with clearance, you'll have a better selection of tyres and the handling will probably be better.
Does need a fender roll though.
edit: these are from guys who seem to only use their cars for the track though.
9" is silly for a DD.
Those are a very similar style to XXR 527's which can be had in 15x8.25 (derp .25" sizes) and a 16x8.25".
Pretty cheap wheels, $115 USD: http://www.nlmotoring.com/XXR-527-Wheel ... 68082n.htm
But they are 0 offset (ugh) and likely to be pretty heavy as they're another knockoff company.
Ridiculous, and wouldn't pay even half as much as they're asking: http://www.trademe.co.nz/a.aspx?id=707449188
...yet for some reason i want one.
http://www.trademe.co.nz/motors/car-par ... 628135.htm
For anyone interested in these I just wanted to give a heads up that Wade(The guy selling them) is not the most trusthworthy character..
I spoke in great detail about the car I bought off him (he insisted no problems) and after already owning a MX5 I knew what questions to ask and it turned out after I booked flights and flew up to Auckland the car had quite a few big problems, gbox, diff, engine mounts, all engine seals, waterpump.... You get the jist many problems which I know I should have just walked away (Got some $$ off) but things became far more apparent halfway down the North Island when I was stranded with an alternator that had just about fallen off the car and then he said when he finds the injectors(that came with the car!) he would post to me FOC at my expense as he believes in karma blah blah blah.
Just wanted to give a heads up if anyone was looking at these as I am sure used injectors can be sourced cheaper and from reputable sources. or even better get some IDs
Liam
Liam
Are you local to Auckland?Junkwhale wrote:Ridiculous, and wouldn't pay even half as much as they're asking: http://www.trademe.co.nz/a.aspx?id=707449188
youtube find !
http://www.youtube.com/watch?v=Ip_iK4mfSF4
there's a rare M2 1028 at about 1:15 :)
