Heated oxygen sensor wiring
Post by warrior » Mon Jan 13, 2014 4:51 pm
That makes sence with the headlights.
I run what is called a powercard, it is a piggyback system that works very well with the supercharger.
I would gain maybe 10hp or so with a megasquirt etc but this system works perfectly. (maybe one day)
Post by warrior » Mon Jan 13, 2014 4:53 pm
Cheers guys, looks like I got a job this weekend. :D
Post by CordedBowl » Mon Jan 13, 2014 4:57 pm
Looks like all of your answers are here if you're using an MTX-L: http://forum.miata.net/vb/showthread.php?t=500416
Post by CordedBowl » Mon Jan 13, 2014 5:01 pm
warrior wrote: I run what is called a powercard, it is a piggyback system that works very well with the supercharger.
Phew, from what I read I thought you were running boosted on the stock ECU and only just got a wideband! :oops:
Post by warrior » Mon Jan 13, 2014 6:27 pm
It is not that brand but I would guess to say it is the same way of installing it.
So I will take out the standard ox sensor all together and install the wideband one in its place, looks like this is the way to go.
If that does not work I have the bung to weld in if I have too.
Post by sprsta » Tue Jan 14, 2014 9:24 am
If you are using the standard ecu you wont be able to feed it the wide band signal since it uses a 5v output and a narrow band uses 1v.
Wideband controllers like Innovate have two separate configurable outputs so you can use one with a linea 5v output to go to the gauge and a 1v
narrowband simulation to go to the ecu.
If you are using an ecu that can take a 5v wideband signal, you can configure the ecu output on the wideband controller to wideband.
If you are using the likes of a G1 FlyinMiatalink wich uses a AEM nonlinea wideband input you can configure the output curve to match
Hope this helps
