Another newbie
Doesnt look too bad but it has been for sale for a few months-maybe 6 even.Probably due to the soft-top...try and listen to it from cold & see if its got the common tick-tick -tick from the hydraulic lifters-no real biggie but a bit annoying.
All helps to know what you are buying in advance.
Best of luck!
Best of luck!
He does say in the comments that the soft top is a bit cracked so i'd probably have to factor in a new one of those.
Hydraulic lifters should be no more annoying than the powersteering pump in my starlet
I should have enough money in a few weeks as i just quit one of my jobs and have a semi-decent payout on the way.
Just went for a test drive of this one.
http://www.trademe.co.nz/motors/used-ca ... 870603.htm
Driveline felt very good, couldnt test how well it could corner because it was a little wet(was a little tail happy
Interior was alright, had a tape player, steering wheel was splitting a bit and it could use a new center console as the plastic was a bit broken in front of the gearstick.
Soft top had a hole in it and the rear window had become detached from rest of the roof. At least it comes with a spare roof
Really considering getting it, hopefully my final pay from work comes through tomorrow.
One thing i noticed in the test drive is how close the pedals are together, the clutch felt like it needed to be a little more to the left
Now you mention it i did try a heal toe maneuver and managed to kick my other foot off the clutchKieran wrote:It just feels close together because the dead pedal sticks out abit you get use to it and the pedals being close together makes it easier to heel-toe
Try sitting further back.
I'd adjusted the seat so my wrist rested on top of the wheel with my arm out so couldnt move much further back
