I'd have thought the lack of a locator ring would have caused balance issues in itself if the wheel wasn't centred properly (which is likely if the wheels and nuts were flat-faced), possibly causing the nuts to fail.Snapfrozen wrote:The rest had some stripped threads. Possibly wheel balance or alignment decided which one came off first
The locator ring makes more sense to me. Well, the lack of locator ring anyway!Mr. Shine wrote:I'd have thought the lack of a locator ring would have caused balance issues in itself if the wheel wasn't centred properly (which is likely if the wheels and nuts were flat-faced), possibly causing the nuts to fail.Snapfrozen wrote:The rest had some stripped threads. Possibly wheel balance or alignment decided which one came off first
Once/if I get the car repaired, goodbye to my plans, I'm just going to sack it. Cannot be bothered with it any more
Again - not to sure.
Although regardless, I was doing 50 K's and I was genuinely being a nanna driver. I have emailed super cheap to let them know as clearly it is a safety hazard..
If need be I can upload pictures of the stripped nuts.
Surely the threads wouldn't have been stripped unless they'd had some sort of substantial force put on them? I know it's all speculation, but if the wheel had been properly centred and the nuts were torqued down evenly and to the correct torque setting, then the nuts surely wouldn't have just stripped themselves?
Or something going out the side of the engine or the engine just dying from bad a/f I guess...Snapfrozen wrote:Don't want to sound pessimistic Chris, but if your goal was to make 250whp, you are going to have more things go wrong than this. Imo, fix it and carry on, you learned a lesson the hard way, but at least it wasn't fire, or a tree
Done the fire trick once, wasn't ideal
Oh no, I knew what I was getting myself into. There wore going to be lots of problems.Snapfrozen wrote:Don't want to sound pessimistic Chris, but if your goal was to make 250whp, you are going to have more things go wrong than this. Imo, fix it and carry on, you learned a lesson the hard way, but at least it wasn't fire, or a tree
But the paint work was 2 or 3 months old, the wheels were 4 days old it was like a kick in the teeth
Well no, there isn't a difference.. But I would feel more comfortable working on the engine than I would on the panels
Like I said though it is just a goal! haha
Long term goal.
Full insurance will definitely be coming in now! Although, I would not have filed a claim with this incident
Long term goal.
The one people ALWAYS forget about with full insurance is "I've never had an accident, 3rd party is fine", but what if you have damage to your vehicle while parked as well
Can't claim on that for 3rd party. Stick it out bro, I'm not the panel king but I've done some DIY work. I reckon take to it with a hammer and see how you go. Can't get worse
Just reading through these posts I might add my 2 cents worth.
I run a 2 piece aftermarket wheel. I have had these wheels on the car for about 16 years and have never run hub rings. I have done many gymkhanas (Grass and tarmac), track days and general hooning around and have never had an issue. I agree that it would help centralise the wheel on the hub but if you have a lot of thread engagement on the studs this would still be adequate. (It’s my intention to machine some up but I really haven’t had the time or the notion).
Looking at the photos the thread on the nut has stripped but the studs are OK? Do the wheels have the tapered steel insert where the nut tightens up on? If that’s the case then I would say the wrong nuts have been used (Based on the photos you have posted), and as a result, there hasn’t been enough thread engagement to support the wheel under load. If whoever sold you the wheel nuts should have known this so you may have a strong case.
Of course I would have to see this in the flesh to confirm.
Chris – although crap like this happens I wouldn’t give up just yet (Unless the car is for sale and I can get it cheap!!).
Where abouts in Auckland are you. I can come around and have a look if you wish.
I have a trade cert in Engineering (Fitting and Turning) but haven’t touched a lathe or milling machine for many years!
EDIT: Which wheels are we talking about? The black ones or pink ones?
You don't run spacers do you? I still think there hasn't been enough thread engagement but as I suggested I would need to have a look at them.
I have been tossing and turning selling it.Growler wrote:Just reading through these posts I might add my 2 cents worth.
I love it to much haha
Thanks so much, you Keith Jones, and Euen have all offered a look! Thanks guys, I have an Insurance Assessor coming to look at it tomorrow (I use him at work as I work in insurance) so I will see what he says.
The lugs on the car are all sweet, just the nuts that have been stripped..
From what I can see, the nuts fit the wheels. I will be having a 50th look tonight when I get home =]
EDIT: Pink wheels.. Unfortunately I brought this car to lear about mechanics and modifying cars. I am in no way saying I am not at fault.. I could be, although I still feel that I should have been made aware of this when purchasing them
HahahaKieran wrote:You work in insurance and you don't have insurance?
Thats like a banker not having a bank account
Yes. I have insurance, just not through this company. I only have third party, was going to make it tp fire and theft on the weekend >.<
