No Spark
No Spark
My NA6 was running fine then the engine died. after stopping for a few minutes I restarted it and headed home, several stops later we got home. After cleaning the air filter the engine ran fine. Two days later it wouldn't start. The engine cranked but won't fire. I discovered weak spark so got new plugs. Great spark (No.1 anyway). Still wouldn't start. Replaced the fuel filter and had fuel getting to the Injector Rail. After a neighbour had a look we had no spark at all. Replaced the coil pack. Still no spark (except the occassional cough)
What could be the problem???? ECU or Igniter maybe.... How would I find out??
Please help, I miss driving my MX
1991 Silver NA 1.6 Manual
Difficult to diagnose without trial and error replacement as you have tried.
It sounds like either the igniter or ECU as you have suggested, but could
be something as simple as a broken earth wire.
Are you a member of the MX5 Club of NZ?
If you are I have a spare igniter and ECU you could borrow to try.
It sounds like the igniter, or it could be the wiring from the igniter to the coils, as there are separate feeds from the igniter to each coil pack. The wire colours are red and white. Have a look to see if one has broken, or partially broken.
If you can't find anything obvious and want to borrow an igniter, PM me. I will be home for a few hours tomorrow, then away again until the 8th.
Users browsing this forum: Bing [Bot] and 40 guests
