turbo converted to a supercharger
Post by SLYDIT » Fri Mar 25, 2016 10:39 am
^^^ THIS^^^^
my mx has 200 hp ATW and its decently fast. driven a 260HPATW MX and its INSANE for a road car.
the TD04 turbo'd mx with 200ish WHP is going to be plenty for the street. a 1600 will make 200WHP all day/year long...an 1800 will do 240WHP all day /year long. my cars been turbo'd for 10 years at 200WHP and i havent opened her up at all. changed the plugs and oil and thats it.
the mx is not a 1600kg skyline that needs mega hp to make it move.
KEEP IT SIMPLE
KEEP IT SIMPLE
KEEP IT SIMPLE
STOP listening to other "experts" about all that other crap like SC/ etc
peewee69
Post by peewee69 » Sat Aug 13, 2016 6:29 pm
Hi guys I just got a 1998 1.8L MX and was just wanting to now what kW the supercharger kit would put out and it's a 6speed to :) so much nicer to drive
Teamjelly
Post by Teamjelly » Sun Aug 14, 2016 8:55 am
Using the Mini Supercharger or a Sc14 Supercharger
You're looking at around 180-190hp at the wheels (depending on exhaust) with a Water/Meth Injection kit - or REALLY well designed intercooler.
Not massive power - but a good spread of torque throughout the rev range.
Pales in comparison when you can easily get 240-250hp at the wheels with a turbo setup running similar boost but comes down to preference.
The Mini Supercharger is a bit more expensive but makes a beautiful whining noise when on song - which is music to any gearhead.
peewee69
Post by peewee69 » Mon Aug 15, 2016 6:22 pm
I have a gtx/gtr turbo and exhaust manifold and ecu and injectors could I use those to turb my MX or would that not work??
Teamjelly
Post by Teamjelly » Mon Aug 15, 2016 6:40 pm
Only if you want to half-ass it
peewee69
Post by peewee69 » Mon Aug 15, 2016 8:40 pm
It's just in the mean time but will the ECU plug in to the mx or do I need the gtx loon??
1990 1.6L 5 speed mx5 & 1998 1.8L 6 speed
Teamjelly
Post by Teamjelly » Mon Aug 15, 2016 8:43 pm
Not sure
Never really fuddled around with that sort of setup as time spent on sub-par setups just wastes money that could be spent doing it properly
I'm sure Dr Google will be able to help though. :)
peewee69
Post by peewee69 » Mon Aug 15, 2016 8:52 pm
Also do I use the same AFM ?? (Mx5)
peewee69
Post by peewee69 » Mon Aug 15, 2016 8:56 pm
Thanks for the help also Dr Google didn't pop up with anything now of any links?
2low2c
Post by 2low2c » Tue Aug 16, 2016 7:58 am
you can not use a gtx or any 323 ecu because they are distributor not wasted spark.
peewee69
Post by peewee69 » Tue Aug 16, 2016 12:49 pm
is there any way of changing that over or no?? will I need a pnp or could I even use the mx ecu or even get it re-mapd??
Post by siren676 » Tue Aug 16, 2016 6:09 pm
:lol: Not unless you bash a hole in your firewall for a distributor
peewee69
Post by peewee69 » Mon Aug 22, 2016 8:58 pm
Hay teamjelly do you guys have a kit with a bigger supercharger?? And what happened to the HP figures for the turbo kit in ur earlyer post of 400hp for the 1.8L 6speed??
Teamjelly
Post by Teamjelly » Mon Aug 22, 2016 9:46 pm
We can use the Mini R45 blower
It's slightly smaller but spins faster than the Sc14 so makes more power
But anything over 190hp at the wheels and you have to go turbo
As for power figures - if you email me at
MEGASQUIRT@FARMSIDE.CO.NZ
I can send through some dynosheets of my Turbo Mx5 Racecar that makes around 400 engine hp
peewee69
Post by peewee69 » Tue Aug 30, 2016 9:55 pm
Hay teamjelly what is included in your kit? The turbo one and do you need a wide band when you turbo or does the aftermarket ECU do that also do you need a boost gauge or is just so u now we're ur at? And do u need a boost controller or will the ECU do that ? Also il email you tomorrow
Teamjelly
Post by Teamjelly » Wed Aug 31, 2016 1:44 am
We just do a drive in -drive out (wheelspin out) package - which includes everything needed
ECU, injectors, intercooler, manifold, downpipe, HD clutch , oil lines, oil drain, turbo, driveshaft loop , blowoff valve etc and of course labour and dynotuning
Don't need a wideband but we can fit one
Don't need a boost gauge but we can fit one.
ECU can control boost - or can fit a bleed valve and solenoid to run a High/Low Boost switch - which is quite popular
peewee69
Post by peewee69 » Wed Sep 07, 2016 8:16 pm
I'm thinking for my budget supercharger is the way to go bUT I'd rather a turbo but I basically want 200+kw atw can I get that with a supercharger ??
Teamjelly
Post by Teamjelly » Wed Sep 07, 2016 10:27 pm
Nope - unless you want to run NOS
Even 200kw ATW is a lot for a Turbo B6
You need to take a 150kw ATW MX5 for a drive first - you might be surprised
200kw ATW is almost too much for a streetcar
peewee69
Post by peewee69 » Thu Sep 08, 2016 3:09 pm
I have a 1998 1.8L 6speed now got it a couple weeks ago would I get 200kw+ if I supercharged that??
Teamjelly
Post by Teamjelly » Thu Sep 08, 2016 6:37 pm
Nope
The power is determined by the supercharger rather than the engine
If you want 200kw ATW - then you need an Eaton M90 which is huge and will poke through the bonnet which will make you look silly, get attention from the police, use lots off fuel and cost plenty to install
you have a Nb1800 with 6 speed
Turbo is a natural progression and will make and handle 200kw ATW piece of piss. - and be a really and I mean REALLY fast car.
Easily 12 second 1/4 miles and crap over 99% of cars on the street.
peewee69
Post by peewee69 » Thu Sep 08, 2016 6:45 pm
Oky doky turbo it is what would u think about a t3/t4 on a MX like mine??
Teamjelly
Post by Teamjelly » Thu Sep 08, 2016 6:54 pm
This aint the 1950's mate
The T3/4 is a piece of shit diesel turbo that was designed in 1951 and is probably the worst turbo on the market
I struggle to comprehend why people still bolt them onto engines
Although it's normally Nissan owners which is self-explainatory
A nice Subaru Td05-16g will easily make 200kw ATW on just 16psi be super reliable and will spool up 1500 rpm faster than an old clunker T3/4 turbo
And at $550 brand new is a bit of a no-brainer
Users browsing this forum: No registered users and 90 guests
