not so great roadholding - any suggestions?
jamesdav
Post by jamesdav » Mon Mar 25, 2013 9:43 pm
I recently acquired a 1990 MX5. If it hits a small bump when cornering, the back slips (i.e. momentary loss of road grip). Is this normal for the MX5?
James Davidson
Post by Angreal » Mon Mar 25, 2013 9:54 pm
I'm guessing it's the type of diff it has, or that the shocks aren't particularly good... Mine used to when it was on really bad suspension when I first bought it
Post by tomtikki » Mon Mar 25, 2013 10:14 pm
A small bump? Depending on how much your pushing it, or if you have very stiff springs but no, that is not common for an MX.
It should stick to the road like shit to a blanket, until you push it past it's limits or you purposely make it step out...
Your shocks could be shagged or crap tyres?
Post by sprsta » Mon Mar 25, 2013 10:34 pm
tyres?
Post by Angreal » Tue Mar 26, 2013 12:11 am
Ah yeah, I completely overlooked the obvious :oops: I just assume people have okay tyres...
Re: not so great roadholding - any suggestions?
Post by chris » Tue Mar 26, 2013 11:35 am
jamesdav wrote:I recently acquired a 1990 MX5. If it hits a small bump when cornering, the back slips (i.e. momentary loss of road grip). Is this normal for the MX5?
Yes. Very normal for raodster.
Drifts allways even when going straight.
Careful drifts can be dangerous and people may be hurt.
Post by punkoutnz » Tue Mar 26, 2013 12:28 pm
Could be a wheel alignment issue as well. Too much toe will cause that, or some worn bushes... Basically I'd be having a look at the condition of the rear suspension and bushes in general.
Post by REDBEN » Tue Mar 26, 2013 12:37 pm
Chris is there ever a day your not trolling? Mind you that said your rant about the girl on Facebook who couldn't spell was rather funny 😂
Post by chris » Tue Mar 26, 2013 12:39 pm
Yeah - When people are asking legit questions. I mean no offence to the guy that posted but the first things I would be checking are tyres, and alignment
Post by Growler » Tue Mar 26, 2013 12:54 pm
Check tire pressures as well...
Post by chris » Tue Mar 26, 2013 1:01 pm
Growler wrote:Check tire pressures as well...
Good point. Higher pressures will have you sliding a lot more. Especially in the wet (you don't want to find out the way I did)
Post by jif » Tue Mar 26, 2013 3:18 pm
if it's low enough to be sitting on the bumpstops then yeah, it could be quite slide-y ..
Post by Kieran » Wed Mar 27, 2013 10:07 am
hahahaha I always love this
No it's not unusual for the back to slide out in an mx5 just takes getting used too
There are some basic ways to make it happen less often
1. Tyres
2. Shocks & Springs
3. Wheel Alignment (Get some new eccentric bolts they don't hold alignment as well when they are worn)
4. >30 PSI of Tyre pressure
5. Stiffer Bushes
6. Sway Bars
If all this fails get an open diff cause you can't drive :lol:
